[postgis-tickets] [PostGIS] #4136: st_removerepeatedpoints not fully working in 2.4.4
trac at osgeo.org
Fri Jul 27 00:58:22 PDT 2018
Reporter: jhaagmans | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Keywords: |
When running PostGIS version 2.4.4 I see the following behaviour:
select ST_REMOVEREPEATEDPOINTS('POLYGON((0 0,0 1,1 1,1 1,1 0,0
0))'::geometry);
-> POLYGON ((0 0, 0 1, 1 1, 1 1, 1 0, 0 0))
(note that the second `1 1` should be removed, but isn't)
When adding a new point at `1 2` after the second `1 1`, it works though:
select ST_REMOVEREPEATEDPOINTS('POLYGON((0 0,0 1,1 1,1 1,1 2,1 0,0
0))'::geometry);
-> POLYGON ((0 0, 0 1, 1 1, 1 2, 1 0, 0 0))
I discussed this on IRC where someone noted that this does work on the
current 2.5.0beta, but as this is a production workload running on AWS RDS
I probably shouldn't use a beta version and I thought I should report this
behaviour anyway for posterity.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4136>
