[postgis-tickets] r16672 - cu_in_wkt: Fix memory leaks in tests
Raul
raul at rmr.ninja
Fri Jul 27 04:28:00 PDT 2018
Author: algunenano
Date: 2018-07-27 04:28:00 -0700 (Fri, 27 Jul 2018)
New Revision: 16672
trunk/liblwgeom/cunit/cu_in_wkt.c
Introduced in #4109
Modified: trunk/liblwgeom/cunit/cu_in_wkt.c
--- trunk/liblwgeom/cunit/cu_in_wkt.c 2018-07-25 20:34:03 UTC (rev 16671)
+++ trunk/liblwgeom/cunit/cu_in_wkt.c 2018-07-27 11:28:00 UTC (rev 16672)
@@ -356,27 +356,30 @@
lwgeom_parser_result_init(&p);
rv = lwgeom_parse_wkt(&p, wkt, LW_PARSER_CHECK_ALL);
CU_ASSERT_EQUAL( rv, LW_FAILURE );
+ lwgeom_parser_result_free(&p);
wkt = "LINESTRING(1.1 .1, 2.2 .2)";
CU_ASSERT_EQUAL( rv, LW_SUCCESS );
wkt = "LINESTRING( 1.1 .1 , 2.2 .2 )";
wkt = "LINESTRING(\n1.1\n.1,\n2.2\n.2\n)";
wkt = "LINESTRING(1.1\t.1\t,\t2.2\t.2\t)";
@@ -403,4 +406,4 @@
PG_ADD_TEST(suite, test_wkt_in_polyhedralsurface);
PG_ADD_TEST(suite, test_wkt_in_errlocation);
PG_ADD_TEST(suite, test_wkt_double);
\ No newline at end of file
