[postgis-tickets] [PostGIS] #4137: PostGIS 2.5.0beta1 fails tests on MIPS
PostGIS trac at osgeo.org
Sat Jul 28 03:29:36 PDT 2018
 Reporter:  komzpa   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Debian build farm broke the test:
 https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=mips&ver=2.5.0~beta1%2Bdfsg-1~exp2&stamp=1531788162&raw=0
             </gml:Polygon>'));
 Dropping cluster 10/regress ...
  ### /tmp/pgis_reg/test_117_diff ###
 --- minimum_clearance_expected  2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_117_out  2018-07-17 00:33:14.403382003 +0000
 @@ -5,5 +5,5 @@
  t5|t
  t6|t
  t7|t
 -t8|t
 +t8|f
  t9|t
  ### /tmp/pgis_reg/test_134_diff ###
 --- sfcgal/tickets_expected     2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_134_out  2018-07-17 00:37:03.373003132 +0000
 @@ -138,8 +138,8 @@
  #712|t
  #756.1|t|t
  #1023|t
 -#1023.a|f
 -#1023.b|t
 +#1023.a|t
 +#1023.b|f
  #1060|FFFFFFFF2
  #1273|t
  #1273.1|t
 @@ -242,6 +242,6 @@
  #2108|SRID=3395;POINTM EMPTY
  #2117|SRID=3395;POINTM EMPTY
  #2110.1|f
 -#2110.2|t
 +#2110.2|f
  #2110.3|t
  #2145|6792004
  ### /tmp/pgis_reg/test_55_diff ###
 --- operators_expected  2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_55_out   2018-07-16 22:03:37.751593535 +0000
 @@ -43,7 +43,7 @@
  ab3|t
  eq1|t
  eq2|f
 -eq3|f
 +eq3|t
  cd1|4
  bd1|0
  bd2|1
  ### /tmp/pgis_reg/test_94_diff ###
 --- tickets_expected    2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_94_out   2018-07-16 22:13:37.051799048 +0000
 @@ -139,8 +139,8 @@
  #712|t
  #756.1|t|t
  #1023|t
 -#1023.a|f
 -#1023.b|t
 +#1023.a|t
 +#1023.b|f
  #1060|FFFFFFFF2
  #1273|t
  #1273.1|t
 @@ -178,7 +178,7 @@
  #1453.2|f
  #1454|t
  #1414|CURVEPOLYGON Z EMPTY
 -#1478|010100002001000000000000000000f87f000000000000f87f
 +#1478|010100002001000000fffffffffffff77ffffffffffffff77f
  #745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
  #1450|POINT|POLYGON
  #1482|4326
 @@ -234,7 +234,7 @@
  #2110.1|f
 -#2110.2|t
 +#2110.2|f
  #2110.3|t
  #2145|6792004
  #2232|M 0 0 l 0 0 1 0 0 0 1 0 0 0
 @@ -304,10 +304,9 @@
  #3627a|o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?
  #3627b|t
  #3704|t
 -#3709|t
 +#3709|f
  #3774|t
  #1014a|POINT(0 0)
 -#1014a|POINT(0 0)
  #1014b|POINT(0 1)
  #1014c|1|POINT(0 1)
  #1014c|2|POINT(1 2)
  ### /tmp/pgis_reg/test_97_diff ###
 --- wkb_expected        2018-07-03 20:26:25.000000000 +0000
 +++ /tmp/pgis_reg/test_97_out   2018-07-16 22:14:09.084024845 +0000
 @@ -1,7 +1,7 @@
 -POINT
 EMPTY|0101000000000000000000f87f000000000000f87f|t|00000000017ff80000000000007ff8000000000000
 -POINT Z
 EMPTY|01e9030000000000000000f87f000000000000f87f000000000000f87f|t|00000003e97ff80000000000007ff80000000000007ff8000000000000
 -POINT M
 EMPTY|01d1070000000000000000f87f000000000000f87f000000000000f87f|t|00000007d17ff80000000000007ff80000000000007ff8000000000000
 -POINT ZM
 EMPTY|01b90b0000000000000000f87f000000000000f87f000000000000f87f000000000000f87f|t|0000000bb97ff80000000000007ff80000000000007ff80000000000007ff8000000000000
 +POINT
 EMPTY|0101000000fffffffffffff77ffffffffffffff77f|t|00000000017ff7ffffffffffff7ff7ffffffffffff
 +POINT Z
 EMPTY|01e9030000fffffffffffff77ffffffffffffff77ffffffffffffff77f|t|00000003e97ff7ffffffffffff7ff7ffffffffffff7ff7ffffffffffff
 +POINT M
 EMPTY|01d1070000fffffffffffff77ffffffffffffff77ffffffffffffff77f|t|00000007d17ff7ffffffffffff7ff7ffffffffffff7ff7ffffffffffff
 +POINT ZM
 EMPTY|01b90b0000fffffffffffff77ffffffffffffff77ffffffffffffff77ffffffffffffff77f|t|0000000bb97ff7ffffffffffff7ff7ffffffffffff7ff7ffffffffffff7ff7ffffffffffff
  POINT(0
 0)|010100000000000000000000000000000000000000|t|000000000100000000000000000000000000000000
  POINT Z (1 2
 3)|01e9030000000000000000f03f00000000000000400000000000000840|t|00000003e93ff000000000000040000000000000004008000000000000
  POINT M (1 2
 3)|01d1070000000000000000f03f00000000000000400000000000000840|t|00000007d13ff000000000000040000000000000004008000000000000
 @@ -55,8 +55,8 @@
  GEOMETRYCOLLECTION ZM (POINT ZM (0 0 0 0),LINESTRING ZM (0 0 0 0,1 1 1
 1))|01bf0b00000200000001b90b0000000000000000000000000000000000000000000000000000000000000000000001ba0b0000020000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f|t|0000000bbf000000020000000bb900000000000000000000000000000000000000000000000000000000000000000000000bba0000000200000000000000000000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff00000000000003ff0000000000000
  GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1
 1))|01d70700000200000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f|t|00000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff0000000000000
 1),GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1
 1)))|01d70700000300000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f01d70700000200000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f|t|00000007d70000000300000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff0000000000000
 -GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1 1),POINT M
 EMPTY,GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1
 1)))|01d70700000400000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f01d1070000000000000000f87f000000000000f87f000000000000f87f01d70700000200000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f|t|00000007d70000000400000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d17ff80000000000007ff80000000000007ff800000000000000000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff0000000000000
 1),GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1 1),POINT
 M EMPTY,GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1
 1))),POINT M EMPTY,GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0
 0,1 1
 1)))|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|t|00000007d70000000500000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d70000000400000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d17ff80000000000007ff80000000000007ff800000000000000000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d17ff80000000000007ff80000000000007ff800000000000000000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff0000000000000
 +GEOMETRYCOLLECTION M (POINT M (0 0 0),LINESTRING M (0 0 0,1 1 1),POINT M
 1)))|01d70700000400000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f01d1070000fffffffffffff77ffffffffffffff77ffffffffffffff77f01d70700000200000001d107000000000000000000000000000000000000000000000000000001d207000002000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f|t|00000007d70000000400000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff000000000000000000007d17ff7ffffffffffff7ff7ffffffffffff7ff7ffffffffffff00000007d70000000200000007d100000000000000000000000000000000000000000000000000000007d2000000020000000000000000000000000000000000000000000000003ff00000000000003ff00000000000003ff0000000000000
 0,1 1
 1)))|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|t|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
  CIRCULARSTRING EMPTY|010800000000000000|t|000000000800000000
  CIRCULARSTRING Z EMPTY|01f003000000000000|t|00000003f000000000
  CIRCULARSTRING M EMPTY|01d807000000000000|t|00000007d800000000
  ### end of log dumps ###
 (set -e; \
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4137>
