[postgis-tickets] [PostGIS] #4139: Unstable behavior of gist nd indexes
trac at osgeo.org
Mon Jul 30 06:20:54 PDT 2018
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
I'm not able to reproduce it with trunk:
index_test=# select count(*) from tbl_geomcollection_nd t1,
tbl_geomcollection_nd t2 where t1.g &&& t2.g;
count
4451734
(1 row)
count
4451734
(1 row)
index_test=# EXPLAIN ANALYZE select count(*) from tbl_geomcollection_nd
t1, tbl_geomcollection_nd t2 where t1.g &&& t2.g;
QUERY PLAN
Aggregate (cost=10000001376.15..10000001376.16 rows=1 width=8) (actual
time=1889.556..1889.556 rows=1 loops=1)
-> Nested Loop (cost=10000000000.15..10000001364.00 rows=4860
width=0) (actual time=0.085..1705.876 rows=4451734 loops=1)
-> Seq Scan on tbl_geomcollection_nd t1
(cost=10000000000.00..10000000186.00 rows=2400 width=596) (actual
time=0.014..0.338 rows
=2400 loops=1)
-> Index Scan using tbl_geomcollection_nd_gist_nd_idx on
tbl_geomcollection_nd t2 (cost=0.14..0.48 rows=1 width=596) (actual tim
e=0.019..0.603 rows=1855 loops=2400)
Index Cond: (t1.g &&& g)
Planning Time: 0.424 ms
Execution Time: 1889.612 ms
(7 rows)
index_test=#
Can you report what Postgis and Postgresql versions are you using? Also an
`EXPLAIN
ANALYZE` of the query.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4139#comment:5>
