[postgis-tickets] [PostGIS] #4139: Unstable behavior of gist nd indexes
trac at osgeo.org
Mon Jul 30 07:12:00 PDT 2018
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by ezimanyi):
I downloaded and installed yesterday the last bundle available here
http://download.osgeo.org/postgis/windows/pg10/
SELECT version() || ' ' || postgis_full_version();
-- "PostgreSQL 10.1, compiled by Visual C++ build 1800, 64-bit
POSTGIS="2.4.4 r16526" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.4, released 2018/03/19"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER"
drop table if exists tbl_geomcollection_nd;
create table tbl_geomcollection_nd (
k serial,
g geometry
insert into tbl_geomcollection_nd (g)
(select g from tbl_geompoint limit 30) union
(select g from tbl_geompointz limit 30) union
(select g from tbl_geompointm limit 30) union
(select g from tbl_geompointzm limit 30) union
(select g from tbl_geomlinestring limit 30) union
(select g from tbl_geomlinestringz limit 30) union
(select g from tbl_geomlinestringm limit 30) union
(select g from tbl_geomlinestringzm limit 30) union
(select g from tbl_geompolygon limit 30) union
(select g from tbl_geompolygonz limit 30) union
(select g from tbl_geompolygonm limit 30) union
(select g from tbl_geompolygonzm limit 30) union
(select g from tbl_geommultipoint limit 30) union
(select g from tbl_geommultipointz limit 30) union
(select g from tbl_geommultipointm limit 30) union
(select g from tbl_geommultipointzm limit 30) union
(select g from tbl_geommultilinestring limit 30) union
(select g from tbl_geommultilinestringz limit 30) union
(select g from tbl_geommultilinestringm limit 30) union
(select g from tbl_geommultilinestringzm limit 30) union
(select g from tbl_geommultipolygon limit 30) union
(select g from tbl_geommultipolygonz limit 30) union
(select g from tbl_geommultipolygonm limit 30) union
(select g from tbl_geommultipolygonzm limit 30) ;
-- Query returned successfully: 720 rows affected, 662 msec execution
time.
drop index if exists tbl_geomcollection_nd_gist_nd_idx;
create index tbl_geomcollection_nd_gist_nd_idx on tbl_geomcollection_nd
using gist(g gist_geometry_ops_nd);
set enable_indexscan = off;
set enable_bitmapscan = off;
set enable_seqscan = on;
select count(*) from tbl_geomcollection_nd t1, tbl_geomcollection_nd t2
where t1.g &&& t2.g
-- 396140
explain analyze
where t1.g &&& t2.g
"Aggregate (cost=7897.56..7897.57 rows=1 width=8) (actual
time=1684.293..1684.293 rows=1 loops=1)"
" -> Nested Loop (cost=0.00..7892.20 rows=2145 width=0) (actual
time=0.078..1609.226 rows=396140 loops=1)"
" Join Filter: (t1.g &&& t2.g)"
" Rows Removed by Join Filter: 122260"
" -> Seq Scan on tbl_geomcollection_nd t1 (cost=0.00..57.20
rows=720 width=625) (actual time=0.029..0.697 rows=720 loops=1)"
" -> Materialize (cost=0.00..60.80 rows=720 width=625) (actual
time=0.000..0.098 rows=720 loops=720)"
" -> Seq Scan on tbl_geomcollection_nd t2 (cost=0.00..57.20
rows=720 width=625) (actual time=0.016..0.354 rows=720 loops=1)"
"Planning time: 0.403 ms"
"Execution time: 1684.731 ms"
set enable_indexscan = on;
set enable_seqscan = off;
where t1.g &&& t2.g
-- 396100
explain analyze
where t1.g &&& t2.g
"Aggregate (cost=10000000420.96..10000000420.97 rows=1 width=8) (actual
time=737.204..737.205 rows=1 loops=1)"
" -> Nested Loop (cost=10000000000.14..10000000415.60 rows=2145
width=0) (actual time=0.329..657.469 rows=396100 loops=1)"
(cost=10000000000.00..10000000057.20 rows=720 width=625) (actual
time=0.034..0.339 rows=720 loops=1)"
" -> Index Scan using tbl_geomcollection_nd_gist_nd_idx on
tbl_geomcollection_nd t2 (cost=0.14..0.49 rows=1 width=625) (actual
time=0.107..0.796 rows=550 loops=720)"
" Index Cond: (t1.g &&& g)"
"Planning time: 1.061 ms"
"Execution time: 737.288 ms"
where t1.g &&& t2.g
-- 396140
where t1.g &&& t2.g
-- 396124
where t1.g &&& t2.g
-- 396128
In our development machine I needed to increase the size of the tables to
reproduce the problem
"PostgreSQL 11beta1 on x86_64-pc-linux-gnu, compiled by clang version
5.0.0 (tags/RELEASE_500/final), 64-bit POSTGIS="2.5.0beta1dev r16611"
[EXTENSION] PGSQL="110" GEOS="3.6.2-CAPI-1.10.2 4d2925d6" PROJ="Rel.
4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, release (...)"
k serial,
g geometry
(select g from tbl_geompoint limit 100) union
(select g from tbl_geompointz limit 100) union
(select g from tbl_geompointm limit 100) union
(select g from tbl_geompointzm limit 100) union
(select g from tbl_geomlinestring limit 100) union
(select g from tbl_geomlinestringz limit 100) union
(select g from tbl_geomlinestringm limit 100) union
(select g from tbl_geomlinestringzm limit 100) union
(select g from tbl_geompolygon limit 100) union
(select g from tbl_geompolygonz limit 100) union
(select g from tbl_geompolygonm limit 100) union
(select g from tbl_geompolygonzm limit 100) union
(select g from tbl_geommultipoint limit 100) union
(select g from tbl_geommultipointz limit 100) union
(select g from tbl_geommultipointm limit 100) union
(select g from tbl_geommultipointzm limit 100) union
(select g from tbl_geommultilinestring limit 100) union
(select g from tbl_geommultilinestringz limit 100) union
(select g from tbl_geommultilinestringm limit 100) union
(select g from tbl_geommultilinestringzm limit 100) union
(select g from tbl_geommultipolygon limit 100) union
(select g from tbl_geommultipolygonz limit 100) union
(select g from tbl_geommultipolygonm limit 100) union
(select g from tbl_geommultipolygonzm limit 100) ;
-- Query returned successfully: 720 rows affected, 94 msec execution time.
where t1.g &&& t2.g
-- 4455622
explain analyze
where t1.g &&& t2.g
"Aggregate (cost=86804.40..86804.41 rows=1 width=8) (actual
time=10509.189..10509.189 rows=1 loops=1)"
" -> Nested Loop (cost=0.00..86790.00 rows=5760 width=0) (actual
time=0.019..10117.923 rows=4455622 loops=1)"
" Rows Removed by Join Filter: 1304378"
" -> Seq Scan on tbl_geomcollection_nd t1 (cost=0.00..192.00
rows=2400 width=32) (actual time=0.009..0.987 rows=2400 loops=1)"
" -> Materialize (cost=0.00..204.00 rows=2400 width=32) (actual
time=0.000..0.136 rows=2400 loops=2400)"
(cost=0.00..192.00 rows=2400 width=32) (actual time=0.002..0.742 rows=2400
loops=1)"
"Planning Time: 0.096 ms"
"Execution Time: 10509.285 ms"
where t1.g &&& t2.g
-- 4455551
explain analyze
where t1.g &&& t2.g
"Aggregate (cost=10000001408.47..10000001408.48 rows=1 width=8) (actual
time=3889.217..3889.217 rows=1 loops=1)"
" -> Nested Loop (cost=10000000000.15..10000001394.00 rows=5788
width=0) (actual time=0.082..3470.596 rows=4455551 loops=1)"
(cost=10000000000.00..10000000192.00 rows=2400 width=626) (actual
time=0.018..0.427 rows=2400 loops=1)"
tbl_geomcollection_nd t2 (cost=0.14..0.49 rows=1 width=626) (actual
time=0.045..1.265 rows=1856 loops=2400)"
"Planning Time: 0.268 ms"
"Execution Time: 3889.255 ms"
where t1.g &&& t2.g
-- 4455562
where t1.g &&& t2.g
-- 4455504
where t1.g &&& t2.g
-- 4455537
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4139#comment:6>
