[postgis-tickets] r17620 - postgis_extensions_upgrade() also updates after pg_upgrade
Raul
raul at rmr.ninja
Mon Jul 22 06:27:46 PDT 2019
Author: algunenano
Date: 2019-07-22 06:27:46 -0700 (Mon, 22 Jul 2019)
New Revision: 17620
trunk/NEWS
trunk/postgis/postgis.sql.in
Closes #4271
Closes https://github.com/postgis/postgis/pull/449
Modified: trunk/NEWS
--- trunk/NEWS 2019-07-22 11:35:56 UTC (rev 17619)
+++ trunk/NEWS 2019-07-22 13:27:46 UTC (rev 17620)
@@ -15,6 +15,7 @@
- #4456, add Rasbery Pi 32-bit jenkins bot for testing (Bruce Rindahl)
- #4454, Speed up _ST_OrderingEquals (Raúl Marín)
- #4453, Speed up ST_IsEmpty (Raúl Marín)
+ - #4271, postgis_extensions_upgrade() also updates after pg_upgrade (Raúl Marín)
PostGIS 3.0.0alpha3
2019/07/01
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-07-22 11:35:56 UTC (rev 17619)
+++ trunk/postgis/postgis.sql.in 2019-07-22 13:27:46 UTC (rev 17620)
@@ -2854,11 +2854,11 @@
rec.name, rec.installed_version, rec.default_version;
RAISE DEBUG '%', sql;
EXECUTE sql;
- ELSIF rec.default_version = rec.installed_version AND
- rec.installed_version ILIKE '%dev'
+ ELSIF (rec.default_version = rec.installed_version AND rec.installed_version ILIKE '%dev') OR
+ (@extschema at ._postgis_pgsql_version() != @extschema at ._postgis_scripts_pgsql_version())
THEN
-- we need to upgrade to next and back
- RAISE NOTICE 'Updating dev extension % %',
+ RAISE NOTICE 'Updating extension % %',
rec.name, rec.installed_version;
sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
quote_ident(rec.default_version || 'next') || ';';
