[postgis-tickets] [PostGIS] #4462: st_asmvtgeom fails with IllegalArgumentException: RobustDeterminant encountered non-finite numbers
trac at osgeo.org
Tue Jul 23 09:36:57 PDT 2019
Reporter: autra | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.5.x
Keywords: |
= description
Using st_asmvtgeom in a query, I sometimes have the following error:
NOTICE: LWGEOM_GEOS_nodeLines(): IllegalArgumentException:
ERROR: IllegalArgumentException: RobustDeterminant encountered non-finite
numbers
= Steps
- restore the attached dump in a database with postgis extension
- use the following query
{{{#!sql
select st_asmvtgeom(geom,
st_setsrid(st_makebox2d(st_point(1645442.8949999844, 8184994.56999849),
st_point
(1647681.2699999844,8187432.94499849)), 3949)) as mvtgeom from copy3;
**expected**
The query resumes without errors
**actual**
The query fails with the following error:
NOTICE: 00000: LWGEOM_GEOS_nodeLines(): IllegalArgumentException:
ERROR: XX000: IllegalArgumentException: RobustDeterminant encountered
non-finite numbers
= Additional informations
The following queries **does** succeed:
With a larger extent:
{{{#!sql
st_setsrid(st_makebox2d(st_point(1545442.8949999844, 8084994.56999849),
st_point
(1747681.2699999844,8287432.94499849)), 3949)) as mvtgeom from copy3;
When I intersect before using st_asmvtgeom:
{{{#!sql
select
st_asmvtgeom(
st_intersection(
geom,
8184994.56999849), st_point(1647681.2699999844,8187432.94499849)), 3949)
8184994.56999849), st_point(1647681.2699999844,8187432.94499849)), 3949))
as mvtgeom
from copy3;
= Context
# select version();
PostgreSQL 10.9 (Ubuntu 10.9-0ubuntu0.18.10.1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 8.3.0-6ubuntu1~18.10.1) 8.3.0, 64-bit
# select postgis_version();
2.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I also reproduce with postgis 2.4
thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4462>
