[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
trac at osgeo.org
Tue Jul 30 09:54:23 PDT 2019
Reporter: constant5 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: arm |
System Ubuntu 18.04 AArch64
This is a challenging install on an arm system.
Steps:
1. built and installed proj-6.1.1 from source
2. built and installed geos_3.7.2-1 from source
3. built and installed gdal-3.0.1 from source
4. built and installed postgis_3.0.0alpha_dev from source
executed :sudo ldconfig
Trying:
testdb=# CREATE EXTENSION postgis;
ERROR: could not load library "/usr/lib/postgresql/10/lib/postgis-3.so":
/usr/lib/postgresql/10/lib/postgis-3.so: undefined symbol: proj_get_type
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467>
