[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
PostGIS trac at osgeo.org
Tue Jul 30 12:59:50 PDT 2019
  Reporter:  constant5  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.0.0
 Component:  postgis    |    Version:  trunk
Resolution:             |   Keywords:  arm
Comment (by constant5):
 I must I have an older proj libary loaded beacuse i get:
 libproj.so.12 => /usr/lib/aarch64-linux-gnu/libproj.so.12
 (0x0000007fb7ba0000)
 How do I change the library that is linked?
 when I run proj in the bash terminal it says I have version 6.1 and when I
 configure the postgis build it says it finds proj 61?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467#comment:2>
