[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
PostGIS trac at osgeo.org
Wed Jul 31 07:30:45 PDT 2019
  Reporter:  constant5  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.0.0
 Component:  postgis    |    Version:  trunk
Resolution:             |   Keywords:  arm
Comment (by constant5):
 OK. I uninstalled all proj related packages including some V4 ubuntu
 distributions that I must have forgotten to delete after unsuccessfully
 trying to install everything from apt.
 I started over with the steps above.
 1. built and installed proj-6.1.1 from source
 2. built and installed geos_3.7.2-1 from source
 3. built and installed gdal-3.0.1 from source
 4. built and installed postgis_3.0.0alpha_dev from source
 Now I get a new error:
 testdb=# CREATE EXTENSION postgis;
 ERROR:  could not load library "/usr/lib/postgresql/10/lib/postgis-3.so":
 /usr/lib/postgresql/10/lib/postgis-3.so: undefined symbol:
 GEOSFrechetDistanceDensify
 I am attaching the ldd output so you can see if postgis has the
 appropriate libraries.
 ldd /usr/lib/postgresql/10/lib/postgis-3.so
         linux-vdso.so.1 (0x0000007fb7c75000)
         libgtk3-nocsd.so.0 => /usr/lib/aarch64-linux-
 gnu/libgtk3-nocsd.so.0 (0x0000007fb7b26000)
         libgeos_c.so.1 => /usr/lib/aarch64-linux-gnu/libgeos_c.so.1
 (0x0000007fb7ae4000)
         libproj.so.15 => /usr/local/lib/libproj.so.15 (0x0000007fb7895000)
         libjson-c.so.3 => /lib/aarch64-linux-gnu/libjson-c.so.3
 (0x0000007fb787b000)
         libxml2.so.2 => /usr/lib/aarch64-linux-gnu/libxml2.so.2
 (0x0000007fb76dc000)
         libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007fb7583000)
         /lib/ld-linux-aarch64.so.1 (0x0000007fb7c4a000)
         libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2
 (0x0000007fb756e000)
         libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0
 (0x0000007fb7542000)
         libgeos-3.6.2.so => /usr/lib/aarch64-linux-gnu/libgeos-3.6.2.so
 (0x0000007fb7397000)
         libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6
 (0x0000007fb7204000)
         libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1
 (0x0000007fb71e0000)
         libsqlite3.so.0 => /usr/lib/aarch64-linux-gnu/libsqlite3.so.0
 (0x0000007fb70e5000)
         libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007fb702b000)
         libicuuc.so.60 => /usr/lib/aarch64-linux-gnu/libicuuc.so.60
 (0x0000007fb6e56000)
         libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000007fb6e29000)
         liblzma.so.5 => /lib/aarch64-linux-gnu/liblzma.so.5
 (0x0000007fb6df9000)
         libicudata.so.60 => /usr/lib/aarch64-linux-gnu/libicudata.so.60
 (0x0000007fb5440000)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467#comment:3>
