[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
PostGIS trac at osgeo.org
Wed Jul 31 07:40:45 PDT 2019
  Reporter:  constant5              |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  arm
Changes (by Algunenano):
 * owner:  pramsey => strk
 * component:  postgis => build/upgrade/install
Comment:
 You are building against geos 3.7.2, but it's loading geos 3.6.2:
 libgeos-3.6.2.so => /usr/lib/aarch64-linux-gnu/libgeos-3.6.2.so
 (0x0000007fb7397000)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467#comment:4>
