[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
PostGIS trac at osgeo.org
Wed Jul 31 07:43:24 PDT 2019
  Reporter:  constant5  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.0.0
 Component:  postgis    |    Version:  trunk
Resolution:             |   Keywords:  arm
Changes (by constant5):
 * owner:  strk => pramsey
 * component:  build/upgrade/install => postgis
Comment:
 So I checked and like proj I still had some older geos packages installed.
 I removed them, recompiled, and everything works!
 testdb=# CREATE EXTENSION postgis;
 CREATE EXTENSION
 Is there a way in future releases to prevent postgis from using legacy
 libraries?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467#comment:5>
