[postgis-tickets] [PostGIS] #4467: Error: undefined symbol: proj_get_type when installed from source
PostGIS trac at osgeo.org
Wed Jul 31 08:00:21 PDT 2019
  Reporter:  constant5              |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:  arm
Changes (by Algunenano):
 * owner:  pramsey => strk
 * status:  new => closed
 * component:  postgis => build/upgrade/install
 * resolution:   => fixed
Comment:
 > Is there a way in future releases to prevent postgis from using legacy
 libraries?
 We can't really do anything to "fix" your setup. I'd recommend not
 installing more than one version of a library unless you know how library
 dynamic loading works.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4467#comment:6>
