[postgis-tickets] [PostGIS] #4338: Census block level data (tabblock table) not installing
trac at osgeo.org
Tue Mar 5 12:27:28 PST 2019
Reporter: jedaniel | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.5.2
Component: tiger geocoder | Version: 2.5.x
Keywords: census block tabblock windows |
When trying to install the Census tract, bg, and tabblock (census blocks)
data, the tabblock table is never populated (tract and bg tables appear
fine) under Windows. Have not tested this under Linux nor OSX, but
problem persisted across multiple states, and appears whether one uses
loader_generate_script() (with appropriate UPDATE
tiger.loader_lookuptables) or loader_generate_census_script() functions.
As best I can tell, the problem stems from this line in the generated
batch file that are supposed to import the data:
%PSQL% -c "ALTER TABLE tiger_staging.MA_tract RENAME geoid TO tract_id;
SELECT loader_load_staged_data(lower('MA_tract'), lower('MA_tract')); "
The problem stems from the ALTER TABLE statement in this line which
incorrectly tries to rename **geoid** column of the table
**tiger_staging.MA_tabblock**, which does not exist. If the ALTER
statement fails, then loader_load_staged_data() fails due to mismatched
column names (i.e. geoid is supposed to be renamed to tract_id).
Altering the line as follows appears to remedy the problem:
%PSQL% -c "ALTER TABLE tiger_staging.MA_tabblock10 RENAME geoid10 TO
tabblock_id; SELECT loader_load_staged_data(lower('MA_tabblock10'),
lower('MA_tabblock')); "
That is to say, the proper name of the table in tiger_staging should be
**MA_tabblock10** and not **MA_tabblock**.
Fixing the loader_generate_script batch file by hand appears to remedy the
problem, but hopefully a more elegant solution can be applied down the
line.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4338>
