[postgis-tickets] r17298 - Use "support function" API in PgSQL 12+ to provide index support for ST_Intersects and company, in place of old SQL inlining method.
Paul Ramsey
pramsey at cleverelephant.ca
Wed Mar 6 09:27:24 PST 2019
Author: pramsey
Date: 2019-03-06 09:27:24 -0800 (Wed, 06 Mar 2019)
New Revision: 17298
trunk/NEWS
trunk/doc/reference_measure.xml
trunk/postgis/Makefile.in
trunk/postgis/geography.sql.in
trunk/postgis/geography_measurement.c
trunk/postgis/gserialized_gist_2d.c
trunk/postgis/lwgeom_geos.c
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_after.sql
trunk/regress/core/tickets.sql
trunk/utils/create_undef.pl
Closes #4341
Modified: trunk/NEWS
--- trunk/NEWS 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/NEWS 2019-03-06 17:27:24 UTC (rev 17298)
@@ -31,6 +31,8 @@
- #4311, Introduce `--with-wagyu` as an option for MVT polygons (Raúl Marín)
* Enhancements and fixes *
+ - #4341, Using "support function" API in PgSQL 12+ to replace SQL inlining
+ as the mechanism for providing index support under ST_Intersects, et al
- #4322, Support for Proj 6+ API, bringing more accurate datum transforms
and support for WKT projections
- #4153, ST_Segmentize now splits segments proportionally (Darafei
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/doc/reference_measure.xml 2019-03-06 17:27:24 UTC (rev 17298)
@@ -3082,20 +3082,8 @@
<paramdef><type>double precision </type>
<parameter>distance_meters</parameter></paramdef>
- </funcprototype>
- <funcprototype>
- <funcdef>boolean <function>ST_DWithin</function></funcdef>
- <paramdef><type>geography </type>
- <parameter>gg1</parameter></paramdef>
- <parameter>gg2</parameter></paramdef>
- <paramdef><type>double precision </type>
- <parameter>distance_meters</parameter></paramdef>
- <paramdef><type>boolean </type>
+ <paramdef choice="opt"><type>boolean </type>
<parameter>use_spheroid</parameter></paramdef>
</funcprototype>
</funcsynopsis>
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/Makefile.in 2019-03-06 17:27:24 UTC (rev 17298)
@@ -106,6 +106,7 @@
gserialized_typmod.o \
gserialized_gist_2d.o \
gserialized_gist_nd.o \
+ gserialized_supportfn.o \
$(SPGIST_OBJ) \
brin_2d.o \
brin_nd.o \
Modified: trunk/postgis/geography.sql.in
--- trunk/postgis/geography.sql.in 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/geography.sql.in 2019-03-06 17:27:24 UTC (rev 17298)
@@ -520,15 +520,7 @@
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
COST 100;
--- Stop calculation and return immediately once distance is less than tolerance
-- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION _ST_DWithin(geography, geography, float8, boolean)
- RETURNS boolean
- AS 'MODULE_PATHNAME','geography_dwithin'
- LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
- COST 100;
--- Availability: 1.5.0
CREATE OR REPLACE FUNCTION ST_Distance(geography, geography, boolean)
RETURNS float8
AS 'SELECT @extschema at ._ST_Distance($1, $2, 0.0, $3)'
@@ -555,26 +547,8 @@
COST 50;
-CREATE OR REPLACE FUNCTION ST_DWithin(geography, geography, float8, boolean)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3, $4)'
- LANGUAGE 'sql' IMMUTABLE _PARALLEL;
--- Currently defaulting to spheroid calculations
-CREATE OR REPLACE FUNCTION ST_DWithin(geography, geography, float8)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3, true)'
--- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
-CREATE OR REPLACE FUNCTION ST_DWithin(text, text, float8)
- RETURNS boolean AS
- $$ SELECT @extschema at .ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3); $$
-- Distance/DWithin testing functions for cached operations.
-- For developer/tester use only.
@@ -682,40 +656,6 @@
AS 'MODULE_PATHNAME','geography_point_outside'
LANGUAGE 'c' IMMUTABLE STRICT;
--- Only implemented for polygon-over-point
-CREATE OR REPLACE FUNCTION _ST_Covers(geography, geography)
- RETURNS boolean
- AS 'MODULE_PATHNAME','geography_covers'
- COST 100;
-CREATE OR REPLACE FUNCTION ST_Covers(geography, geography)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($1, $2)'
-CREATE OR REPLACE FUNCTION ST_Covers(text, text)
- $$ SELECT @extschema at .ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry); $$
-CREATE OR REPLACE FUNCTION ST_CoveredBy(geography, geography)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($2, $1)'
-CREATE OR REPLACE FUNCTION ST_CoveredBy(text, text)
- $$ SELECT @extschema at .ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry); $$
-- Availability: 2.1.0
CREATE OR REPLACE FUNCTION ST_Segmentize(geog geography, max_segment_length float8)
RETURNS geography
@@ -724,18 +664,6 @@
COST 100;
-CREATE OR REPLACE FUNCTION ST_Intersects(geography, geography)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Distance($1, $2, 0.0, false) < 0.00001'
-CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
- $$ SELECT @extschema at .ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry); $$
CREATE OR REPLACE FUNCTION _ST_BestSRID(geography, geography)
RETURNS integer
AS 'MODULE_PATHNAME','geography_bestsrid'
@@ -863,3 +791,118 @@
LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
+-- Only implemented for polygon-over-point
+-- Availability: 1.5.0
+CREATE OR REPLACE FUNCTION _ST_Covers(geog1 geography, geog2 geography)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','geography_covers'
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
+ COST 100;
+-- Stop calculation and return immediately once distance is less than tolerance
+CREATE OR REPLACE FUNCTION _ST_DWithin(geog1 geography, geog2 geography, tolerance float8, use_spheroid boolean DEFAULT true)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','geography_dwithin'
+ COST 100;
+-- Availability: 3.0.0
+CREATE OR REPLACE FUNCTION _ST_CoveredBy(geog1 geography, geog2 geography)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','geography_coveredby'
+ COST 100;
+#if POSTGIS_PGSQL_VERSION >= 120
+CREATE OR REPLACE FUNCTION ST_Covers(geog1 geography, geog2 geography)
+ RETURNS boolean
+ SUPPORT postgis_index_supportfn
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_DWithin(geog1 geography, geog2 geography, tolerance float8, use_spheroid boolean DEFAULT true)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_CoveredBy(geog1 geography, geog2 geography)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Intersects(geog1 geography, geog2 geography)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','geography_intersects'
+ COST 100;
+#else
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($1, $2)'
+ LANGUAGE 'sql' IMMUTABLE _PARALLEL;
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($2, $1)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3, $4)'
+CREATE OR REPLACE FUNCTION ST_Intersects(geography, geography)
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Distance($1, $2, 0.0, false) < 0.00001'
+#endif
+-- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
+CREATE OR REPLACE FUNCTION ST_Covers(text, text)
+ RETURNS boolean AS
+ $$ SELECT @extschema at .ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+CREATE OR REPLACE FUNCTION ST_CoveredBy(text, text)
+ $$ SELECT @extschema at .ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+CREATE OR REPLACE FUNCTION ST_DWithin(text, text, float8)
+ $$ SELECT @extschema at .ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3); $$
+CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
+ $$ SELECT @extschema at .ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry); $$
Modified: trunk/postgis/geography_measurement.c
--- trunk/postgis/geography_measurement.c 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/geography_measurement.c 2019-03-06 17:27:24 UTC (rev 17298)
@@ -58,6 +58,7 @@
Datum geography_expand(PG_FUNCTION_ARGS);
Datum geography_point_outside(PG_FUNCTION_ARGS);
Datum geography_covers(PG_FUNCTION_ARGS);
+Datum geography_coveredby(PG_FUNCTION_ARGS);
Datum geography_bestsrid(PG_FUNCTION_ARGS);
Datum geography_perimeter(PG_FUNCTION_ARGS);
Datum geography_project(PG_FUNCTION_ARGS);
@@ -267,33 +268,13 @@
-** geography_dwithin(GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, boolean use_spheroid)
-** returns double distance in meters
-PG_FUNCTION_INFO_V1(geography_dwithin);
-Datum geography_dwithin(PG_FUNCTION_ARGS)
+static bool
+geography_dwithin_impl(FunctionCallInfo fcinfo, GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, bool use_spheroid)
- GSERIALIZED *g1 = NULL;
- GSERIALIZED *g2 = NULL;
- double tolerance = 0.0;
double distance;
- bool use_spheroid = true;
SPHEROID s;
int dwithin = LW_FALSE;
- /* Get our geometry objects loaded into memory. */
- g1 = PG_GETARG_GSERIALIZED_P(0);
- g2 = PG_GETARG_GSERIALIZED_P(1);
- /* Read our tolerance value. */
- if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
- tolerance = PG_GETARG_FLOAT8(2);
- /* Read our calculation type. */
- if ( PG_NARGS() > 3 && ! PG_ARGISNULL(3) )
- use_spheroid = PG_GETARG_BOOL(3);
error_if_srid_mismatch(gserialized_get_srid(g1), gserialized_get_srid(g2));
/* Initialize spheroid */
@@ -305,11 +286,7 @@
/* Return FALSE on empty arguments. */
if ( gserialized_is_empty(g1) || gserialized_is_empty(g2) )
- PG_FREE_IF_COPY(g1, 0);
- PG_FREE_IF_COPY(g2, 1);
- PG_RETURN_BOOL(false);
+ return false;
/* Do the brute force calculation if the cached calculation doesn't tick over */
if ( LW_FAILURE == geography_dwithin_cache(fcinfo, g1, g2, &s, tolerance, &dwithin) )
@@ -325,14 +302,50 @@
lwgeom_free(lwgeom2);
- /* Clean up */
+ return dwithin;
+** geography_dwithin(GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, boolean use_spheroid)
+** returns double distance in meters
+PG_FUNCTION_INFO_V1(geography_dwithin);
+Datum geography_dwithin(PG_FUNCTION_ARGS)
+ GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+ double tolerance = 0.0;
+ bool use_spheroid = true;
+ bool dwithin = false;
+ /* Read our tolerance value. */
+ if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
+ tolerance = PG_GETARG_FLOAT8(2);
+ /* Read our calculation type. */
+ if ( PG_NARGS() > 3 && ! PG_ARGISNULL(3) )
+ use_spheroid = PG_GETARG_BOOL(3);
+ dwithin = geography_dwithin_impl(fcinfo, g1, g2, tolerance, use_spheroid);
+ PG_RETURN_BOOL(dwithin);
+PG_FUNCTION_INFO_V1(geography_intersects);
+Datum geography_intersects(PG_FUNCTION_ARGS)
+ bool dwithin = geography_dwithin_impl(fcinfo, g1, g2, tolerance, use_spheroid);
+ PG_FREE_IF_COPY(g1, 0);
+ PG_FREE_IF_COPY(g2, 1);
** geography_distance_tree(GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, boolean use_spheroid)
@@ -769,6 +782,48 @@
PG_RETURN_BOOL(result);
+PG_FUNCTION_INFO_V1(geography_coveredby);
+ LWGEOM *lwgeom1 = NULL;
+ LWGEOM *lwgeom2 = NULL;
+ GSERIALIZED *g1 = NULL;
+ GSERIALIZED *g2 = NULL;
+ int result = LW_FALSE;
+ /* Get our geometry objects loaded into memory. */
+ /* Pick them up in reverse order to covers */
+ g1 = PG_GETARG_GSERIALIZED_P(1);
+ g2 = PG_GETARG_GSERIALIZED_P(0);
+ /* Construct our working geometries */
+ lwgeom1 = lwgeom_from_gserialized(g1);
+ lwgeom2 = lwgeom_from_gserialized(g2);
+ error_if_srid_mismatch(lwgeom1->srid, lwgeom2->srid);
+ /* EMPTY never intersects with another geometry */
+ if ( lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
+ lwgeom_free(lwgeom1);
+ lwgeom_free(lwgeom2);
+ PG_FREE_IF_COPY(g1, 1);
+ PG_FREE_IF_COPY(g2, 0);
+ PG_RETURN_BOOL(false);
+ /* Calculate answer */
+ result = lwgeom_covers_lwgeom_sphere(lwgeom1, lwgeom2);
+ /* Clean up */
+ PG_RETURN_BOOL(result);
** geography_bestsrid(GSERIALIZED *g, GSERIALIZED *g) returns int
** Utility function. Returns negative SRID numbers that match to the
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/gserialized_gist_2d.c 2019-03-06 17:27:24 UTC (rev 17298)
@@ -383,8 +383,13 @@
if ( box2df_is_empty(a) && ! box2df_is_empty(b) )
return true;
- POSTGIS_DEBUG(5, "entered function");
- return box2df_contains(b,a);
+ if ( (a->xmin < b->xmin) || (a->xmax > b->xmax) ||
+ (a->ymin < b->ymin) || (a->ymax > b->ymax) )
+ return false;
+ return true;
bool box2df_equals(const BOX2DF *a, const BOX2DF *b)
@@ -987,7 +992,7 @@
break;
case RTContainedByStrategyNumber:
case RTOldContainedByStrategyNumber:
- retval = (bool) box2df_contains(query, key);
+ retval = (bool) box2df_within(key, query);
break;
/* To one side */
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/lwgeom_geos.c 2019-03-06 17:27:24 UTC (rev 17298)
@@ -73,6 +73,7 @@
Datum ST_Intersects(PG_FUNCTION_ARGS);
Datum crosses(PG_FUNCTION_ARGS);
Datum contains(PG_FUNCTION_ARGS);
+Datum within(PG_FUNCTION_ARGS);
Datum containsproperly(PG_FUNCTION_ARGS);
Datum covers(PG_FUNCTION_ARGS);
Datum overlaps(PG_FUNCTION_ARGS);
@@ -1610,26 +1611,20 @@
-PG_FUNCTION_INFO_V1(contains);
-Datum contains(PG_FUNCTION_ARGS)
+static bool
+containsImpl(FunctionCallInfo fcinfo, GSERIALIZED *geom1, GSERIALIZED *geom2)
- GSERIALIZED *geom1;
- GSERIALIZED *geom2;
GEOSGeometry *g1, *g2;
GBOX box1, box2;
int result;
PrepGeomCache *prep_cache;
- geom1 = PG_GETARG_GSERIALIZED_P(0);
- geom2 = PG_GETARG_GSERIALIZED_P(1);
errorIfGeometryCollection(geom1,geom2);
error_if_srid_mismatch(gserialized_get_srid(geom1), gserialized_get_srid(geom2));
/* A.Contains(Empty) == FALSE */
if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
+ return false;
POSTGIS_DEBUG(3, "contains called.");
@@ -1637,10 +1632,11 @@
** short-circuit 1: if geom2 bounding box is not completely inside
** geom1 bounding box we can return FALSE.
- if ( gserialized_get_gbox_p(geom1, &box1) &&
- gserialized_get_gbox_p(geom2, &box2) )
+ if (gserialized_get_gbox_p(geom1, &box1) &&
+ gserialized_get_gbox_p(geom2, &box2))
- if (!gbox_contains_2d(&box1, &box2)) PG_RETURN_BOOL(false);
+ if (!gbox_contains_2d(&box1, &box2))
+ return false;
@@ -1695,12 +1691,10 @@
/* Never get here */
elog(ERROR,"Type isn't point or multipoint!");
- PG_RETURN_NULL();
+ return false;
- PG_FREE_IF_COPY(geom1, 0);
- PG_FREE_IF_COPY(geom2, 1);
- PG_RETURN_BOOL(retval);
+ return retval > 0;
else
@@ -1739,13 +1733,32 @@
if (result == 2) HANDLE_GEOS_ERROR("GEOSContains");
+ return result > 0;
+PG_FUNCTION_INFO_V1(contains);
+Datum contains(PG_FUNCTION_ARGS)
+ GSERIALIZED *geom0 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(1);
+ bool result = containsImpl(fcinfo, geom0, geom1);
+ PG_FREE_IF_COPY(geom0, 0);
+ PG_FREE_IF_COPY(geom1, 1);
+PG_FUNCTION_INFO_V1(within);
+ bool result = containsImpl(fcinfo, geom1, geom0);
PG_FUNCTION_INFO_V1(containsproperly);
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/postgis.sql.in 2019-03-06 17:27:24 UTC (rev 17298)
@@ -221,7 +221,7 @@
AS 'MODULE_PATHNAME','LWGEOM_m_point'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
CREATE OR REPLACE FUNCTION box3d_in(cstring)
@@ -537,6 +537,7 @@
AS 'MODULE_PATHNAME', 'gserialized_gist_joinsel_nd'
LANGUAGE 'c' _PARALLEL;
-- GEOMETRY Operators
@@ -3508,20 +3509,6 @@
COST 1; -- reset cost, see #3675
--- Only accepts LINESTRING as parameters.
--- Availability: 1.4.0
-CREATE OR REPLACE FUNCTION _ST_LineCrossingDirection(geom1 geometry, geom2 geometry)
- RETURNS integer
- AS 'MODULE_PATHNAME', 'ST_LineCrossingDirection'
- COST 100; -- Guessed cost
-CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(geom1 geometry, geom2 geometry)
- RETURNS integer AS
- $$ SELECT CASE WHEN NOT $1 OPERATOR(@extschema at .&&) $2 THEN 0 ELSE @extschema at ._ST_LineCrossingDirection($1,$2) END $$
-- Availability: 1.3.3
CREATE OR REPLACE FUNCTION ST_SimplifyPreserveTopology(geometry, float8)
RETURNS geometry
@@ -4160,20 +4147,16 @@
AS 'MODULE_PATHNAME','disjoint'
--- PostGIS equivalent function: touches(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION _ST_Touches(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'MODULE_PATHNAME','touches'
+-- Non-indexed functions (see above for public indexed variants)
+-- Availability: 1.4.0
+CREATE OR REPLACE FUNCTION _ST_LineCrossingDirection(line1 geometry, line2 geometry)
+ RETURNS integer
+ AS 'MODULE_PATHNAME', 'ST_LineCrossingDirection'
+ COST 100;
--- Availability: 1.2.2
--- Inlines index magic
-CREATE OR REPLACE FUNCTION ST_Touches(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Touches($1,$2)'
-- Availability: 1.3.4
CREATE OR REPLACE FUNCTION _ST_DWithin(geom1 geometry, geom2 geometry,float8)
RETURNS boolean
@@ -4182,12 +4165,13 @@
-CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
+CREATE OR REPLACE FUNCTION _ST_Touches(geom1 geometry, geom2 geometry)
RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3)'
+ AS 'MODULE_PATHNAME','touches'
+ COST 100; -- Guessed cost
--- PostGIS equivalent function: intersects(geom1 geometry, geom2 geometry)
+-- Availability: 1.2.2
CREATE OR REPLACE FUNCTION _ST_Intersects(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'MODULE_PATHNAME','ST_Intersects'
@@ -4195,13 +4179,6 @@
-CREATE OR REPLACE FUNCTION ST_Intersects(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Intersects($1,$2)'
--- PostGIS equivalent function: crosses(geom1 geometry, geom2 geometry)
CREATE OR REPLACE FUNCTION _ST_Crosses(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'MODULE_PATHNAME','crosses'
@@ -4209,13 +4186,6 @@
-CREATE OR REPLACE FUNCTION ST_Crosses(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Crosses($1,$2)'
--- PostGIS equivalent function: contains(geom1 geometry, geom2 geometry)
CREATE OR REPLACE FUNCTION _ST_Contains(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'MODULE_PATHNAME','contains'
@@ -4222,12 +4192,19 @@
+CREATE OR REPLACE FUNCTION _ST_ContainsProperly(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','containsproperly'
-CREATE OR REPLACE FUNCTION ST_Contains(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION _ST_Covers(geom1 geometry, geom2 geometry)
RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Contains($1,$2)'
+ AS 'MODULE_PATHNAME', 'covers'
CREATE OR REPLACE FUNCTION _ST_CoveredBy(geom1 geometry, geom2 geometry)
@@ -4237,54 +4214,229 @@
-CREATE OR REPLACE FUNCTION ST_CoveredBy(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION _ST_Within(geom1 geometry, geom2 geometry)
RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .@) $2 AND @extschema at ._ST_CoveredBy($1,$2)'
+ AS 'SELECT @extschema at ._ST_Contains($2,$1)'
-CREATE OR REPLACE FUNCTION _ST_Covers(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION _ST_Overlaps(geom1 geometry, geom2 geometry)
RETURNS boolean
- AS 'MODULE_PATHNAME', 'covers'
+ AS 'MODULE_PATHNAME','overlaps'
-CREATE OR REPLACE FUNCTION ST_Covers(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION _ST_DFullyWithin(geom1 geometry, geom2 geometry,float8)
RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Covers($1,$2)'
+ AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin'
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+CREATE OR REPLACE FUNCTION _ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME', 'LWGEOM_dwithin3d'
+ COST 100;
+CREATE OR REPLACE FUNCTION _ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin3d'
+ COST 100;
+CREATE OR REPLACE FUNCTION _ST_3DIntersects(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME', 'ST_3DIntersects'
+ COST 100;
+-- Planner Support Functions
+-- Availability 3.0.0
+CREATE OR REPLACE FUNCTION postgis_index_supportfn (internal)
+ RETURNS internal
+ AS 'MODULE_PATHNAME', 'postgis_index_supportfn'
+ LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION _ST_ContainsProperly(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'MODULE_PATHNAME','containsproperly'
+CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(geom1 geometry, geom2 geometry)
+ RETURNS integer
+-- Availability: 1.3.4
+CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry,float8)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME', 'LWGEOM_dwithin'
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Touches(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Intersects(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','ST_Intersects'
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Crosses(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','crosses'
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Contains(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME','contains'
+ COST 100;
CREATE OR REPLACE FUNCTION ST_ContainsProperly(geom1 geometry, geom2 geometry)
RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_ContainsProperly($1,$2)'
+ COST 100;
--- PostGIS equivalent function: overlaps(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION _ST_Overlaps(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION ST_Within(geom1 geometry, geom2 geometry)
RETURNS boolean
+ AS 'MODULE_PATHNAME','within'
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Covers(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_CoveredBy(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'MODULE_PATHNAME', 'coveredby'
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_Overlaps(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ COST 100;
--- PostGIS equivalent function: within(geom1 geometry, geom2 geometry)
-CREATE OR REPLACE FUNCTION _ST_Within(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION ST_DFullyWithin(geom1 geometry, geom2 geometry,float8)
RETURNS boolean
- AS 'SELECT @extschema at ._ST_Contains($2,$1)'
+CREATE OR REPLACE FUNCTION ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
+ RETURNS boolean
+ COST 100;
+CREATE OR REPLACE FUNCTION ST_3DIntersects(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ COST 100;
+#else
+CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(line1 geometry, line2 geometry)
+ RETURNS integer AS
+ $$ SELECT CASE WHEN NOT $1 OPERATOR(@extschema at .&&) $2 THEN 0 ELSE @extschema at ._ST_LineCrossingDirection($1,$2) END $$
+CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Touches($1,$2)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Intersects($1,$2)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Crosses($1,$2)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Contains($1,$2)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .@) $2 AND @extschema at ._ST_CoveredBy($1,$2)'
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Covers($1,$2)'
+CREATE OR REPLACE FUNCTION ST_ContainsProperly(geom1 geometry, geom2 geometry)
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_ContainsProperly($1,$2)'
RETURNS boolean
AS 'SELECT $2 OPERATOR(@extschema at .~) $1 AND @extschema at ._ST_Contains($2,$1)'
@@ -4291,12 +4443,38 @@
RETURNS boolean
AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Overlaps($1,$2)'
+CREATE OR REPLACE FUNCTION ST_DFullyWithin(geom1 geometry, geom2 geometry, float8)
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DFullyWithin(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2), $3)'
+ LANGUAGE 'sql' IMMUTABLE;
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDWithin($1, $2, $3)'
+ COST 100;
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDFullyWithin($1, $2, $3)'
+ COST 100;
+ RETURNS boolean
+ AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_3DIntersects($1, $2)'
+ COST 100;
+#endif
-- PostGIS equivalent function: IsValid(geometry)
-- TODO: change null returns to true
CREATE OR REPLACE FUNCTION ST_IsValid(geometry)
@@ -5433,16 +5611,6 @@
AS 'SELECT @extschema at ._ST_LongestLine(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2))'
-CREATE OR REPLACE FUNCTION _ST_DFullyWithin(geom1 geometry, geom2 geometry,float8)
- RETURNS boolean
- AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin'
- LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-CREATE OR REPLACE FUNCTION ST_DFullyWithin(geom1 geometry, geom2 geometry, float8)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DFullyWithin(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2), $3)'
- LANGUAGE 'sql' IMMUTABLE;
-- Availability: 2.2.0
CREATE OR REPLACE FUNCTION ST_SwapOrdinates(geom geometry, ords cstring)
RETURNS geometry
@@ -5813,42 +5981,7 @@
-CREATE OR REPLACE FUNCTION _ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
- RETURNS boolean
- AS 'MODULE_PATHNAME', 'LWGEOM_dwithin3d'
- COST 100;
-CREATE OR REPLACE FUNCTION ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDWithin($1, $2, $3)'
- COST 100;
-CREATE OR REPLACE FUNCTION _ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
- RETURNS boolean
- AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin3d'
- COST 100;
-CREATE OR REPLACE FUNCTION ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDFullyWithin($1, $2, $3)'
- COST 100;
-CREATE OR REPLACE FUNCTION _ST_3DIntersects(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'MODULE_PATHNAME', 'ST_3DIntersects'
- COST 100;
-CREATE OR REPLACE FUNCTION ST_3DIntersects(geom1 geometry, geom2 geometry)
- RETURNS boolean
- AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_3DIntersects($1, $2)'
- COST 100;
-- SQL-MM
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/postgis/postgis_drop_after.sql 2019-03-06 17:27:24 UTC (rev 17298)
@@ -104,6 +104,7 @@
DROP FUNCTION IF EXISTS st_box3d(geometry);
DROP FUNCTION IF EXISTS st_box(geometry);
DROP FUNCTION IF EXISTS ST_ConcaveHull(geometry,float); -- this one changed to use default parameters
+DROP FUNCTION IF EXISTS ST_DWithin(geography, geography, float8); -- this one changed to use default parameters
DROP FUNCTION IF EXISTS st_text(geometry);
DROP FUNCTION IF EXISTS st_geometry(box2d);
DROP FUNCTION IF EXISTS st_geometry(box3d);
@@ -177,6 +178,7 @@
DROP FUNCTION IF EXISTS _ST_DistanceRectTreeCached(g1 geometry, g2 geometry);
-- pgis_abs type was increased from 8 bytes in 2.1 to 16 bytes in 2.2
-- See #3460
UPDATE pg_type SET typlen=16 WHERE typname='pgis_abs' AND typlen=8;
Modified: trunk/regress/core/tickets.sql
--- trunk/regress/core/tickets.sql 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/regress/core/tickets.sql 2019-03-06 17:27:24 UTC (rev 17298)
@@ -597,7 +597,7 @@
select ST_Collect('POLYGON EMPTY', 'POLYGON EMPTY') as mp,
'POINT(0 0)'::geometry as p
-select '#1578', _st_within(p, mp), _st_intersects(p, mp) FROM inp;
+select '#1578', st_within(p, mp), st_intersects(p, mp) FROM inp;
-- #1580
select '#1580.1', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
Modified: trunk/utils/create_undef.pl
--- trunk/utils/create_undef.pl 2019-03-06 15:50:34 UTC (rev 17297)
+++ trunk/utils/create_undef.pl 2019-03-06 17:27:24 UTC (rev 17298)
@@ -37,7 +37,8 @@
my @funcs = ();
my @types = ();
my %type_funcs = ();
-my @type_funcs= (); # function to drop _after_ type drop
+my @type_funcs = (); # function to drop _after_ type drop
+my @supp_funcs = ();
my @ops = ();
my @opcs = ();
my @views = ();
@@ -82,11 +83,16 @@
while( my $line = <INPUT>)
if ($line =~ /^create (or replace )?function/i) {
+ my $supp = 0;
my $defn = $line;
while( not $defn =~ /\)/ ) {
$defn .= <INPUT>;
- push (@funcs, $defn)
+ if ($defn =~ /_supportfn /) {
+ $supp = 1;
+ push (@funcs, $defn) if ! $supp;
+ push (@supp_funcs, $defn) if $supp;
elsif ($line =~ /^create or replace view\s*(\w+)/i) {
push (@views, $1);
@@ -283,6 +289,24 @@
+print "-- Drop all support functions.\n";
+foreach my $fn (@supp_funcs)
+ if ($fn =~ /.* function ([^(]+)\((.*)\)/i )
+ my $fn_nm = $1;
+ my $fn_arg = $2;
+ $fn_arg =~ s/DEFAULT [\w']+//ig;
+ print "DROP FUNCTION IF EXISTS $fn_nm ($fn_arg);\n";
+ else
+ die "Couldn't parse line: $fn\n";
print "-- Drop all functions needed for types definition.\n";
foreach my $fn (@type_funcs)
