[postgis-tickets] [PostGIS] #4344: Macro-based COSTS for version specific costing
PostGIS trac at osgeo.org
Fri Mar 8 13:48:08 PST 2019
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 3.0.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17307" 17307]:
 #!CommitTicketReference repository="" revision="17307"
 Add costs to functions in the form of macros:
 _COST_LOW, _COST_MEDIUM, _COST_HIGH
 Macros are set in sqldefines.h.in and are switched
 on PgSQL version. Prior to PG12, costs should be
 small or nonexistent, to avoid SQL inlining issues.
 After Pg12, costs can be higher to hopefully
 force more parallelism in plans.
 Closes #4344
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4344#comment:1>
