[postgis-tickets] [PostGIS] #4345: Can't upgrade from 2.4.2 to 3.0.0dev
trac at osgeo.org
Fri Mar 8 22:24:45 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Dronie is complaining about not being able to upgrade
https://dronie.osgeo.org/postgis/postgis/146/1/2
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade(); to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ERROR: index search operators must return boolean
CONTEXT: SQL statement "
ALTER OPERATOR FAMILY gist_geometry_ops_nd USING gist
ADD OPERATOR 8 @@ (geometry,geometry) ;
PL/pgSQL function inline_code_block line 44 at EXECUTE
make: Leaving directory `/drone/src/topology/test'
FAIL: upgrade 2.4.2--3.0.0dev
make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4345>
