[postgis-tickets] [PostGIS] #4302: ST_MemSize for geography
trac at osgeo.org
Fri Mar 8 23:41:09 PST 2019
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: reopened => closed
* resolution: => wontfix
Comment:
I'm closing this as a wontfix. Of all the functions we could possibly
choose to support for geography, ST_Memsize is up there in the dumbest
category.
That said geography is a second class citizen because it came second and
we purposely DID not just wrap it in geometry because
a) 4326 would then be slow in geometry and often times people just don't
care planar even for 4326 is often good enough
b) We had toyed with autocasts so that geography would just autocast
itself to use geometry functions where it could. We took that out because
it caused too many ambiguous function this and that when people toyed with
using 'POLYGON(....)' and also when it did autocast, it was ahocking
surprise in many cases.
We still have a bit of a shocking surprise that geometry autocasts to
geography as in the case with the stupid hack people use of
ST_Distance(geometry, true)
c) Adding a native geography function for every geometry would balloon our
list of function 300 more and would be a huge pain to maintain.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4302#comment:8>
