[postgis-tickets] [PostGIS] #4330: postgis_restore fails when output piped to an intermediate process
PostGIS trac at osgeo.org
Sat Mar 9 09:35:01 PST 2019
  Reporter:  hranalli               |      Owner:  strk
      Type:  patch                  |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.5.2
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:                         |   Keywords:
Comment (by strk):
 I see the change is in the block parsing CREATE TABLE and in the one
 parsing COMMENT ON
 How do they affect the TABLE DATA block that you reference in the original
 submission ?
 I suspect the problem is elsewhere. Can it be the lack of ^anchor in
 CREATE TABLE pattern ? May it be it is catching TABLE DATA values ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4330#comment:4>
