[postgis-tickets] [PostGIS] #4133: raster2pgsql WARNING: Unable to add constraint: 'regular_blocking'. Skipping
PostGIS trac at osgeo.org
Mon Mar 11 05:12:46 PDT 2019
Skipping
  Reporter:  osgeoap  |      Owner:  Bborie Park
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.7
 Component:  raster   |    Version:  2.4.x
Resolution:  invalid  |   Keywords:  regular_blocking
Changes (by robe):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 I'm guessing the image you tiled and are you are trying to load is not
 regularly blocked.
 Please use our mailing list and provide more details about your image
 https://lists.osgeo.org/mailman/listinfo/postgis-users .  There might be a
 work around for it.
 Thought I didn't think dbmanager cared whether your tiles are regularly
 blocked or not so you might have a different issue here as well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4133#comment:4>
