[postgis-tickets] r17323 - Prep for PostGIS 2.5.2 release
Regina Obe
lr at pcorp.us
Mon Mar 11 05:40:21 PDT 2019
Author: robe
Date: 2019-03-11 05:40:21 -0700 (Mon, 11 Mar 2019)
New Revision: 17323
branches/2.5/ChangeLog
branches/2.5/NEWS
branches/2.5/README.postgis
branches/2.5/Version.config
branches/2.5/doc/release_notes.xml
branches/2.5/extensions/upgradeable_versions.mk
Modified: branches/2.5/ChangeLog
--- branches/2.5/ChangeLog 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/ChangeLog 2019-03-11 12:40:21 UTC (rev 17323)
@@ -1,3 +1,321 @@
+2019-03-10 18:58 Regina Obe <lr at pcorp.us>
+ * [r17321] Make _drop_raster_constraint_spatially_unique and
+ _raster_constraint_info_spatially_unique allow for presence or
+ absense of schema qual on geometry cast.
+ Was failing before when installed as extension (but not by
+ script)
+ Reference #4291 for PostGIS 2.5.2
+2019-03-10 09:07 Regina Obe <lr at pcorp.us>
+ * [r17317] Take out schema qualify in constraint see if it resolves
+ failing check constraint check on bessie and debbie
+2019-03-10 07:20 Regina Obe <lr at pcorp.us>
+ * [r17316] Schema qualify all geometry casts in raster code,
+ otherwise materialized views do not resture
+ Closes #4291 for PostGIS 2.5.2
+ Missed some spots in last commit
+2019-03-09 06:54 Regina Obe <lr at pcorp.us>
+ * [r17313] Schema qualify all geometry casts in raster code,
+2019-03-09 06:29 Regina Obe <lr at pcorp.us>
+ * [r17311] Change de_DE to de. de is the one that is active
+ References #3848 for PostGIS 2.5
+2019-02-21 20:44 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17270] Add extra_float_digits for pg12
+2019-02-15 19:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17256] Update test running instructions
+2019-02-15 18:53 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17253] Update OGC certification scripts to match new SFSQL 1.2
+ signatures
+2019-02-11 17:18 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17237] Add generated file
+ * [r17236] Add lexer initialization
+ References #4017
+2019-02-05 00:41 Regina Obe <lr at pcorp.us>
+ * [r17230] Get rid of sudo -i on the pg11 docker evidentally not
+ installed
+2019-02-04 22:45 Regina Obe <lr at pcorp.us>
+ * [r17228] Fix dronie badge (still need to fix build link)
+2019-01-31 15:49 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17224] PostgreSQL 12 compatibility
+ Initial patch by Laurenz Albe
+ References #4313
+2019-01-30 19:17 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17221] ST_ClipByBox2D: Do not throw when the geometry is
+ invalid
+ Closes #4314
+2019-01-25 11:52 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17215] PG12 compat: Remove unnecessary header include (tqual.h)
+ Closes #4307
+2019-01-22 09:09 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17206] Partially revert r17180
+ It changed the behaviour of _postgis_pgsql_version
+ Now uses the appropiate 5-6 digit version from server_version_num
+ References #4296
+ References #4303
+2019-01-21 19:52 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17199] Sync generated parser to y file, using newer bison
+ version
+2019-01-21 19:24 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17195] Commit generated code to match parser
+ * [r17194] Actually put fix for #4273 in the right place
+ so it isn't blown away when parser.y is evaluated.
+ References #4273
+2019-01-18 21:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17189] Un space
+2019-01-18 20:43 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17186] Avoid final point duplicates for circle stroking
+ References #4283
+2019-01-18 18:02 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17182] More robust geography distance
+ References #4290
+2019-01-18 17:24 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17180] Use `server_version_num` instead of parsing `version()`
+ References #4296
+2019-01-18 16:06 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17175] Avoid passing a NULL pointer to GEOSisEmpty
+ References #4275
+2019-01-18 11:56 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17172] Correct issue reference from previous commit
+ References #4289
+2019-01-18 11:53 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17170] ST_AsMVTGeom: Transform coordinates space before
+ clipping
+ References #4300
+2019-01-17 23:22 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17168] Use AccessShareLock in spatial_index_read_extent
+ References #4261
+2019-01-17 11:32 Darafei Praliaskouski <me at komzpa.net>
+ * [r17164] ST_Subdivide endless loop on coordinates near coincident
+ to bounds
+ Closes #4301
+ Closes https://github.com/postgis/postgis/pull/361
+2019-01-16 10:50 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17161] ST_AsMVTGeom: Always return the simplest geometry
+ Closes #4300
+2019-01-16 09:04 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17159] Tests: Remove warning when building with 32bit arch
+ It appeared when investigating #4298
+2019-01-15 22:16 Regina Obe <lr at pcorp.us>
+ * [r17157] Add dronie.osgeo.org agent config (drone 1.0 standard)
+2019-01-11 12:37 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17135] ST_AsMVT: parse JSON numeric values with decimals as
+ doubles
+ References #4292
+2019-01-10 16:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17131] Remove memory leak in "junky wkt" case
+ References #4273
+2019-01-09 20:09 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17129] Move fix further into parser, fix bad test case
+ References #4273
+2018-12-26 04:06 Regina Obe <lr at pcorp.us>
+ * [r17119] Fix so custom --with-projdir= configure switch works
+ again.
+ References #4279 for PostGIS 2.5
+2018-12-21 05:38 Darafei Praliaskouski <me at komzpa.net>
+ * [r17115] [doc] ST_AsGeoJSON doc refresh
+ Closes #4276
+2018-12-17 10:41 Darafei Praliaskouski <me at komzpa.net>
+ * [r17112] Attribute Raúl Marín for help resolving build issue.
+ References #4254
+2018-12-17 10:34 Darafei Praliaskouski <me at komzpa.net>
+ * [r17109] Support Proj 6. Support is via legacy API, we need to
+ redesign for non-legacy and Proj 7.
+ Closes #4254
+ Closes https://github.com/postgis/postgis/pull/354
+2018-11-30 15:01 Regina Obe <lr at pcorp.us>
+ * [r17089] change winnie to build, test, and package using GEOS
+ 3.7.1 instead of GEOS 3.7.0
+2018-11-29 11:11 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17088] Correct referenfce in NEWS file
+2018-11-29 09:29 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17085] Document MULTISURFACE compatibility of ST_LineToCurve
+ (Steven Ottens)
+ References #4162
+2018-11-27 00:14 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17078] Change test conditions to look for empty.
+ References #4245
+2018-11-25 19:28 Darafei Praliaskouski <me at komzpa.net>
+ * [r17074] Stabilize GiST ND indexes for mixed dimensions
+ Patch by Darafei Praliaskouski
+ Thanks to
+ Arthur Lesuisse for synthesizing test case,
+ Andrew Gierth for finding runaway memcpy,
+ Raúl Marín for pointing to memory problem in index construction.
+ This is not backpatchable to 2.x, that requires separate
+ solution.
+ Closes #4139
+2018-11-23 17:56 Regina Obe <lr at pcorp.us>
+ * [r17063] Get rid of use of oids in topology regress was taken out
+ in PostgreSQL 12.
+ Closes #4251 for PostGIS 2.5.2
+2018-11-23 07:49 Regina Obe <lr at pcorp.us>
+ * [r17061] Missed a spot in last commit
+ Closes #4231 for postgis 2.5.2
+2018-11-22 21:10 Regina Obe <lr at pcorp.us>
+ * [r17060] Add 2.2.8 to upgrade targets
+ Remove using of pg_constraint.consrc to allow support of 12 as
+ noted by Laurenz Albe (pg_constraint.consrc was removed in
+ 12devel)
+2018-11-22 16:16 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17058] Avoid unaligned memory access in BOX2D_out
+ References #4244
+2018-11-22 13:43 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17052] Fix undefined behaviour in ST_3DDistance
+ References #4246
+2018-11-21 14:13 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17042] Fix undefined behaviour in raster intersection
+ References #4249
+2018-11-21 11:45 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17037] Avoid undefined behaviour in next_float functions (Raúl
+ Marín)
+ References #4247
+2018-11-18 21:32 Regina Obe <lr at pcorp.us>
+ * [r17028] Flip to 2.5.2dev
+2018-11-18 21:29 Regina Obe <lr at pcorp.us>
+ * [r17026] Prep for 2.5.1 for real this time
+2018-11-18 09:41 Regina Obe <lr at pcorp.us>
+ * [r17025] Flip back to 2.5.1dev until confirm winnie's issues on
+ #4242 are just winnie's
+2018-11-18 09:19 Regina Obe <lr at pcorp.us>
+ * [r17024] update change log in prep for 2.5.1 release
2018-11-18 08:43 Regina Obe <lr at pcorp.us>
* [r17023] Prepping for 2.5.1 release
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/NEWS 2019-03-11 12:40:21 UTC (rev 17323)
@@ -1,5 +1,5 @@
PostGIS 2.5.2
-XXXX/XX/XX
+2019/03/11
* Bug fixes *
Modified: branches/2.5/README.postgis
--- branches/2.5/README.postgis 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/README.postgis 2019-03-11 12:40:21 UTC (rev 17323)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.5.0rc1
-:Date: 2018-08-19
+:Version: 2.5.2
+:Date: 2019-03-11
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -31,7 +31,7 @@
REQUIREMENTS
-PostGIS is compatible with PostgreSQL 9.4 and above.
+PostGIS is compatible with PostgreSQL 9.4-11.
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
Modified: branches/2.5/Version.config
--- branches/2.5/Version.config 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/Version.config 2019-03-11 12:40:21 UTC (rev 17323)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=2dev
+POSTGIS_MICRO_VERSION=2
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.5/doc/release_notes.xml
--- branches/2.5/doc/release_notes.xml 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/doc/release_notes.xml 2019-03-11 12:40:21 UTC (rev 17323)
@@ -2,7 +2,46 @@
<appendix id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
- <sect1>
+ <sect1>
+ <title>Release 2.5.2</title>
+ <para>Release date: 2019/03/11</para>
+ <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
+ <para>Supported PostgreSQL versions for this release are:
+ PostgreSQL 9.4 - PostgreSQL 11
+ GEOS >= 3.5</para>
+ <simplesect>
+ <title>Bug Fixes</title>
+ <para>#4231, Support for PostgreSQL 12dev (remove use of pg_constraint.consrc)
+ (Regina Obe, Laurenz Albe)</para>
+ <para>#4247, Avoid undefined behaviour in next_float functions (Raúl Marín)</para>
+ <para>#4249, Fix undefined behaviour in raster intersection (Raúl Marín)</para>
+ <para>#4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)</para>
+ <para>#4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)</para>
+ <para>#4139, Make mixed-dimension ND index build tree correctly.
+ WARNING: REINDEX your ND index on tables that have records with different M/Z
+ dimensions for &&& operator to work predictably.
+ (Darafei Praliaskouski, Arthur Lesuisse, Andrew Gierth, Raúl Marín)</para>
+ <para>#4262, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)</para>
+ <para>#4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)</para>
+ <para>#4276, ST_AsGeoJSON documentation refresh (Darafei Praliaskouski)</para>
+ <para>#4273, Tighter parsing of WKT (Paul Ramsey)</para>
+ <para>#4292, ST_AsMVT: parse JSON numeric values with decimals as doubles (Raúl Marín)</para>
+ <para>#4300, ST_AsMVTGeom: Always return the simplest geometry (Raúl Marín)</para>
+ <para>#4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
+ (Darafei Praliaskouski)</para>
+ <para>#4261, Use AccessShareLock in spatial_index_read_extent (Paul Ramsey)</para>
+ <para>#4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)</para>
+ <para>#4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)</para>
+ <para>#4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)</para>
+ <para>#4290, More robust geography distance (Paul Ramsey)</para>
+ <para>#4283, Avoid final point duplicates for circle stroking (Paul Ramsey)</para>
+ <para>#4314, ST_ClipByBox2D: Do not throw when the geometry is invalid (Raúl Marín)</para>
+ <para>#4313, #4307, PostgreSQL 12 compatibility (Laurenz Albe, Raúl Marín)</para>
+ <para>#4290, Schema qualify geometry casts in raster functions (Regina Obe)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.5.1</title>
<para>Release date: 2018/11/18</para>
@@ -30,7 +69,6 @@
<para>#4326, Allocate enough memory in gidx_to_string (Raúl Marín)</para>
<para>#4190, Avoid undefined behaviour in gserialized_estimate</para>
</simplesect>
</sect1>
<sect1>
Modified: branches/2.5/extensions/upgradeable_versions.mk
--- branches/2.5/extensions/upgradeable_versions.mk 2019-03-10 19:04:28 UTC (rev 17322)
+++ branches/2.5/extensions/upgradeable_versions.mk 2019-03-11 12:40:21 UTC (rev 17323)
@@ -34,6 +34,8 @@
2.3.5 \
2.3.6 \
2.3.7 \
+ 2.3.8 \
+ 2.3.9 \
2.4.0 \
2.4.1 \
2.4.2 \
@@ -41,5 +43,7 @@
2.4.4 \
2.4.5 \
2.4.6 \
+ 2.4.7 \
2.5.0 \
- 2.5.1
+ 2.5.1 \
+ 2.5.2dev
