[postgis-tickets] r17332 - Use CallerFInfoFunctionCallN infrastructure
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 11 10:58:07 PDT 2019
Author: pramsey
Date: 2019-03-11 10:58:07 -0700 (Mon, 11 Mar 2019)
New Revision: 17332
trunk/libpgcommon/lwgeom_pg.c
trunk/libpgcommon/lwgeom_pg.h
trunk/postgis/geography_measurement.c
trunk/postgis/lwgeom_geos.c
Closes #4347
Modified: trunk/libpgcommon/lwgeom_pg.c
--- trunk/libpgcommon/lwgeom_pg.c 2019-03-11 17:51:00 UTC (rev 17331)
+++ trunk/libpgcommon/lwgeom_pg.c 2019-03-11 17:58:07 UTC (rev 17332)
@@ -321,3 +321,101 @@
return 1;
+#if POSTGIS_PGSQL_VERSION < 100
+Datum
+CallerFInfoFunctionCall1(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1)
+ FunctionCallInfoData fcinfo;
+ Datum result;
+ InitFunctionCallInfoData(fcinfo, flinfo, 1, collation, NULL, NULL);
+ fcinfo.arg[0] = arg1;
+ fcinfo.argnull[0] = false;
+ result = (*func) (&fcinfo);
+ /* Check for null result, since caller is clearly not expecting one */
+ if (fcinfo.isnull)
+ elog(ERROR, "function %p returned NULL", (void *) func);
+ return result;
+Datum
+CallerFInfoFunctionCall2(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2)
+ Datum result;
+ InitFunctionCallInfoData(fcinfo, flinfo, 2, collation, NULL, NULL);
+ fcinfo.arg[1] = arg2;
+ fcinfo.argnull[1] = false;
+ return result;
+#else
+#if POSTGIS_PGSQL_VERSION < 120
+Datum
+CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3)
+ Datum result;
+ InitFunctionCallInfoData(fcinfo, flinfo, 3, collation, NULL, NULL);
+ fcinfo.arg[2] = arg3;
+ fcinfo.argnull[2] = false;
+ return result;
+#else
+/* PgSQL 12+ still lacks 3-argument version of these functions */
+Datum
+ LOCAL_FCINFO(fcinfo, 3);
+ Datum result;
+ InitFunctionCallInfoData(*fcinfo, flinfo, 3, collation, NULL, NULL);
+ fcinfo->args[0].value = arg1;
+ fcinfo->args[0].isnull = false;
+ fcinfo->args[1].value = arg2;
+ fcinfo->args[1].isnull = false;
+ fcinfo->args[2].value = arg3;
+ fcinfo->args[2].isnull = false;
+ result = (*func) (fcinfo);
+ if (fcinfo->isnull)
+ return result;
+#endif
+#endif
Modified: trunk/libpgcommon/lwgeom_pg.h
--- trunk/libpgcommon/lwgeom_pg.h 2019-03-11 17:51:00 UTC (rev 17331)
+++ trunk/libpgcommon/lwgeom_pg.h 2019-03-11 17:58:07 UTC (rev 17332)
@@ -189,4 +189,12 @@
void lwpgnotice(const char *fmt, ...);
void lwpgwarning(const char *fmt, ...);
+Datum CallerFInfoFunctionCall1(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1);
+Datum CallerFInfoFunctionCall2(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2);
+#endif
+Datum CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3);
#endif /* !defined _LWGEOM_PG_H */
Modified: trunk/postgis/geography_measurement.c
--- trunk/postgis/geography_measurement.c 2019-03-11 17:51:00 UTC (rev 17331)
+++ trunk/postgis/geography_measurement.c 2019-03-11 17:58:07 UTC (rev 17332)
@@ -214,9 +214,11 @@
/* Get our geometry objects loaded into memory. */
g1 = PG_GETARG_GSERIALIZED_P(0);
g2 = PG_GETARG_GSERIALIZED_P(1);
- use_spheroid = PG_GETARG_BOOL(2);
+ if (PG_NARGS() > 2)
+ use_spheroid = PG_GETARG_BOOL(2);
error_if_srid_mismatch(gserialized_get_srid(g1), gserialized_get_srid(g2));
/* Initialize spheroid */
@@ -266,14 +268,29 @@
PG_RETURN_FLOAT8(distance);
-static bool
-geography_dwithin_impl(FunctionCallInfo fcinfo, GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, bool use_spheroid)
+** geography_dwithin(GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, boolean use_spheroid)
+** returns double distance in meters
+PG_FUNCTION_INFO_V1(geography_dwithin);
+Datum geography_dwithin(PG_FUNCTION_ARGS)
+ GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+ SPHEROID s;
+ double tolerance = 0.0;
+ bool use_spheroid = true;
double distance;
- SPHEROID s;
int dwithin = LW_FALSE;
+ /* Read our tolerance value. */
+ if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
+ tolerance = PG_GETARG_FLOAT8(2);
+ /* Read our calculation type. */
+ if ( PG_NARGS() > 3 && ! PG_ARGISNULL(3) )
+ use_spheroid = PG_GETARG_BOOL(3);
@@ -285,7 +302,7 @@
/* Return FALSE on empty arguments. */
if ( gserialized_is_empty(g1) || gserialized_is_empty(g2) )
- return false;
+ PG_RETURN_BOOL(false);
/* Do the brute force calculation if the cached calculation doesn't tick over */
if ( LW_FAILURE == geography_dwithin_cache(fcinfo, g1, g2, &s, tolerance, &dwithin) )
@@ -301,32 +318,6 @@
lwgeom_free(lwgeom2);
- return dwithin;
-** geography_dwithin(GSERIALIZED *g1, GSERIALIZED *g2, double tolerance, boolean use_spheroid)
-** returns double distance in meters
-PG_FUNCTION_INFO_V1(geography_dwithin);
-Datum geography_dwithin(PG_FUNCTION_ARGS)
- GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
- GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
- double tolerance = 0.0;
- bool use_spheroid = true;
- bool dwithin = false;
- /* Read our tolerance value. */
- if ( PG_NARGS() > 2 && ! PG_ARGISNULL(2) )
- tolerance = PG_GETARG_FLOAT8(2);
- /* Read our calculation type. */
- if ( PG_NARGS() > 3 && ! PG_ARGISNULL(3) )
- use_spheroid = PG_GETARG_BOOL(3);
- dwithin = geography_dwithin_impl(fcinfo, g1, g2, tolerance, use_spheroid);
PG_FREE_IF_COPY(g1, 0);
PG_FREE_IF_COPY(g2, 1);
PG_RETURN_BOOL(dwithin);
@@ -335,14 +326,9 @@
PG_FUNCTION_INFO_V1(geography_intersects);
Datum geography_intersects(PG_FUNCTION_ARGS)
- bool dwithin = geography_dwithin_impl(fcinfo, g1, g2, tolerance, use_spheroid);
- PG_FREE_IF_COPY(g1, 0);
- PG_FREE_IF_COPY(g2, 1);
- PG_RETURN_BOOL(dwithin);
+ PG_RETURN_BOOL(CallerFInfoFunctionCall2(
+ geography_dwithin, fcinfo->flinfo, InvalidOid,
+ PG_GETARG_DATUM(0), PG_GETARG_DATUM(1)));
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2019-03-11 17:51:00 UTC (rev 17331)
+++ trunk/postgis/lwgeom_geos.c 2019-03-11 17:58:07 UTC (rev 17332)
@@ -1598,20 +1598,23 @@
PG_RETURN_BOOL(result);
-static bool
-containsImpl(FunctionCallInfo fcinfo, GSERIALIZED *geom1, GSERIALIZED *geom2)
+PG_FUNCTION_INFO_V1(contains);
+Datum contains(PG_FUNCTION_ARGS)
+ GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
+ int result;
GEOSGeometry *g1, *g2;
GBOX box1, box2;
- int result;
PrepGeomCache *prep_cache;
- errorIfGeometryCollection(geom1,geom2);
+ errorIfGeometryCollection(geom1, geom2);
error_if_srid_mismatch(gserialized_get_srid(geom1), gserialized_get_srid(geom2));
/* A.Contains(Empty) == FALSE */
- if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
- return false;
+ if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
POSTGIS_DEBUG(3, "contains called.");
@@ -1623,7 +1626,7 @@
gserialized_get_gbox_p(geom2, &box2))
if (!gbox_contains_2d(&box1, &box2))
- return false;
@@ -1678,7 +1681,7 @@
/* Never get here */
elog(ERROR,"Type isn't point or multipoint!");
- return false;
return retval > 0;
@@ -1720,32 +1723,21 @@
if (result == 2) HANDLE_GEOS_ERROR("GEOSContains");
- return result > 0;
+ PG_FREE_IF_COPY(geom1, 0);
+ PG_FREE_IF_COPY(geom2, 1);
+ PG_RETURN_BOOL(result > 0);
-PG_FUNCTION_INFO_V1(contains);
-Datum contains(PG_FUNCTION_ARGS)
- GSERIALIZED *geom0 = PG_GETARG_GSERIALIZED_P(0);
- GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(1);
- bool result = containsImpl(fcinfo, geom0, geom1);
- PG_FREE_IF_COPY(geom0, 0);
- PG_FREE_IF_COPY(geom1, 1);
- PG_RETURN_BOOL(result);
PG_FUNCTION_INFO_V1(within);
Datum within(PG_FUNCTION_ARGS)
- bool result = containsImpl(fcinfo, geom1, geom0);
+ PG_RETURN_DATUM(CallerFInfoFunctionCall2(contains, fcinfo->flinfo, InvalidOid,
+ PG_GETARG_DATUM(1), PG_GETARG_DATUM(0)));
PG_FUNCTION_INFO_V1(containsproperly);
Datum containsproperly(PG_FUNCTION_ARGS)
