[postgis-tickets] r17338 - Flip to 2.3.10dev, also flip winnie to use latest stable GEOS
Regina Obe lr at pcorp.us
Mon Mar 11 01:05:00 PDT 2019
Author: robe
Date: 2019-03-11 13:05:00 -0700 (Mon, 11 Mar 2019)
New Revision: 17338
   branches/2.3/Version.config
   branches/2.3/ci/winnie/build_postgis.sh
   branches/2.3/ci/winnie/package_postgis.sh
   branches/2.3/ci/winnie/regress_postgis.sh
   branches/2.3/extensions/upgradeable_versions.mk
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config	2019-03-11 20:01:33 UTC (rev 17337)
+++ branches/2.3/Version.config	2019-03-11 20:05:00 UTC (rev 17338)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=9
+POSTGIS_MICRO_VERSION=10dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/ci/winnie/build_postgis.sh
--- branches/2.3/ci/winnie/build_postgis.sh	2019-03-11 20:01:33 UTC (rev 17337)
+++ branches/2.3/ci/winnie/build_postgis.sh	2019-03-11 20:05:00 UTC (rev 17338)
@@ -13,7 +13,7 @@
 #POSTGIS_MICRO_VERSION=0SVN
 #export GCC_TYPE=gcc48  #for pre-4.8.0 compiles this is blank
 export SFCGAL_VER=1.3.2
-export GEOS_VER=3.6.2
+export GEOS_VER=3.7.1
 export GDAL_VER=2.2.4
 export PROJ_VER=4.9.3
Modified: branches/2.3/ci/winnie/package_postgis.sh
--- branches/2.3/ci/winnie/package_postgis.sh	2019-03-11 20:01:33 UTC (rev 17337)
+++ branches/2.3/ci/winnie/package_postgis.sh	2019-03-11 20:05:00 UTC (rev 17338)
@@ -13,7 +13,7 @@
 #export GCC_TYPE=
Modified: branches/2.3/ci/winnie/regress_postgis.sh
--- branches/2.3/ci/winnie/regress_postgis.sh	2019-03-11 20:01:33 UTC (rev 17337)
+++ branches/2.3/ci/winnie/regress_postgis.sh	2019-03-11 20:05:00 UTC (rev 17338)
@@ -1,7 +1,7 @@
 #!/bin/bash
 set -e
Modified: branches/2.3/extensions/upgradeable_versions.mk
--- branches/2.3/extensions/upgradeable_versions.mk	2019-03-11 20:01:33 UTC (rev 17337)
+++ branches/2.3/extensions/upgradeable_versions.mk	2019-03-11 20:05:00 UTC (rev 17338)
@@ -35,7 +35,7 @@
 	2.3.6 \
 	2.3.7 \
 	2.3.8 \
-	2.3.9dev
+	2.3.9
 # This is to avoid forcing "check-installed-upgrades" as a default
 # rule, see https://trac.osgeo.org/postgis/ticket/3420
