[postgis-tickets] r17345 - Avoid installing unneeded raster scripts in contrib dir
Sandro Santilli
strk at kbt.io
Mon Mar 18 12:45:51 PDT 2019
Author: strk
Date: 2019-03-18 12:45:51 -0700 (Mon, 18 Mar 2019)
New Revision: 17345
trunk/.gitignore
trunk/extensions/postgis_raster/Makefile.in
trunk/raster/rt_pg/Makefile.in
Also stop building extension in non-extension things
Modified: trunk/.gitignore
--- trunk/.gitignore 2019-03-18 19:35:43 UTC (rev 17344)
+++ trunk/.gitignore 2019-03-18 19:45:51 UTC (rev 17345)
@@ -109,9 +109,6 @@
postgis/legacy.sql
postgis/postgis.sql
postgis/postgis_proc_set_search_path.sql
-postgis/postgis_for_extension.sql
-postgis/postgis_upgrade_for_extension.sql
-postgis/postgis_upgrade_for_extension.sql.in
postgis/postgis_upgrade.sql*
postgis/sfcgal_upgrade.sql*
postgis/sqldefines.h
@@ -130,8 +127,6 @@
raster/rt_pg/rtpostgis_legacy.sql
raster/rt_pg/rtpostgis_proc_set_search_path.sql
raster/rt_pg/rtpostgis_upgrade.sql.in
-raster/rt_pg/rtpostgis_for_extension.sql
-raster/rt_pg/rtpostgis_upgrade_for_extension.sql.in
raster/rt_pg/rtpostgis_upgrade*.sql
raster/rt_pg/uninstall_rtpostgis.sql
raster/scripts/Makefile
Modified: trunk/extensions/postgis_raster/Makefile.in
--- trunk/extensions/postgis_raster/Makefile.in 2019-03-18 19:35:43 UTC (rev 17344)
+++ trunk/extensions/postgis_raster/Makefile.in 2019-03-18 19:45:51 UTC (rev 17345)
@@ -10,6 +10,9 @@
endif
GREP = @GREP@
+# SQL preprocessor
+SQLPP = @SQLPP@
MICRO_NUMBER = $(shell echo $(EXTVERSION) | \
$(PERL) -pe 's/\d.\d.(\d+)[a-zA-Z]*\d*/$1/'
@@ -86,12 +89,27 @@
#strip BEGIN/COMMIT since these are not allowed in extensions
-sql/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql | sql
+sql/rtpostgis.sql: sql/rtpostgis_for_extension.sql | sql
$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
-sql/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql | sql
+sql/rtpostgis_for_extension.sql: ../../raster/rt_pg/rtpostgis.sql.in | sql
+ $(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
+ $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
+sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
+#this keeps the @extschema at . in place since extension machinery will replace during install
+sql/rtpostgis_upgrade_for_extension.sql: ../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql sql/rtpostgis_upgrade_for_extension.sql.in ../../raster/rt_pg/rtpostgis_drop.sql | sql
+ echo 'BEGIN;' > $@
+ cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
+ echo 'COMMIT;' >> $@
+sql/rtpostgis_upgrade_for_extension.sql.in: sql/rtpostgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl | sql
+ $(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
../../doc/raster_comments.sql:
$(MAKE) -C ../../doc comments
Modified: trunk/raster/rt_pg/Makefile.in
--- trunk/raster/rt_pg/Makefile.in 2019-03-18 19:35:43 UTC (rev 17344)
+++ trunk/raster/rt_pg/Makefile.in 2019-03-18 19:45:51 UTC (rev 17345)
@@ -29,7 +29,7 @@
endif
# Files to be copied to the contrib/ directory
-DATA_built=rtpostgis.sql rtpostgis_for_extension.sql rtpostgis_upgrade_for_extension.sql rtpostgis_upgrade.sql rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
+DATA_built=rtpostgis.sql rtpostgis_upgrade.sql rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
DATA=
# SQL preprocessor
@@ -77,7 +77,7 @@
SHLIB_LINK_F = ../rt_core/librtcore.a $(LIBLWGEOM_LDFLAGS) $(LIBPGCOMMON_LDFLAGS) $(LIBGDAL_LDFLAGS) @SHLIB_LINK@
# Extra files to remove during 'make clean'
-EXTRA_CLEAN=$(SQL_OBJS) $(DATA_built) rtpostgis_upgrade.sql.in rtpostgis_upgrade_for_extension.sql.in
+EXTRA_CLEAN=$(SQL_OBJS) $(DATA_built) rtpostgis_upgrade.sql.in
# PGXS information
PG_CONFIG := @PG_CONFIG@
@@ -114,10 +114,6 @@
$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
-rtpostgis_for_extension.sql: rtpostgis.sql.in
- $(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
- $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
../../liblwgeom/.libs/liblwgeom.a:
$(MAKE) -C ../../liblwgeom
@@ -139,9 +135,6 @@
rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
-rtpostgis_upgrade_for_extension.sql.in: rtpostgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl
- $(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
rtpostgis_proc_set_search_path.sql: rtpostgis.sql ../../utils/postgis_proc_set_search_path.pl
$(PERL) ../../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
@@ -150,12 +143,6 @@
-#this keeps the @extschema at . in place since extension machinery will replace during install
-rtpostgis_upgrade_for_extension.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade_for_extension.sql.in rtpostgis_drop.sql
- echo 'BEGIN;' > $@
- cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
- echo 'COMMIT;' >> $@
uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_undef.pl
$(PERL) ../../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
