[postgis-tickets] [PostGIS] #4355: PostGIS raster extension is broken
PostGIS trac at osgeo.org
Wed Mar 20 10:19:19 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 debbie, dronie, and winnie are complaining about the same thing.
 Which I think started happening around r17345
 winnie:
 https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/8889/consoleFull
 dronie: https://dronie.osgeo.org/postgis/postgis/171/3/2
 debbie: https://debbie.postgis.net/job/PostGIS_Regress/11576/consoleFull
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis_raster
 Died at ../../../regress/run_test.pl line 1331.
  failed (Error encountered creating EXTENSION POSTGIS_RASTER:
 /projects/postgis/tmp/3.0.0dev_pg11_geos3.8.0dev_gdal2.2.4w64/regress_log)
 sh: createlang: command not found
 CREATE EXTENSION
 ERROR:  could not access file "$libdir/postgis_raster-3": No such file or
 directory
 Makefile:181: recipe for target 'check' failed
 make[3]: *** [check] Error 1
 make[3]: Leaving directory
 '/projects/postgis/branches/3.0/raster/test/regress'
 Makefile:18: recipe for target 'check' failed
 make[2]: *** [check] Error 2
 make[2]: Leaving directory '/projects/postgis/branches/3.0/raster/test'
 Makefile:69: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/3.0/raster'
 GNUmakefile:20: recipe for target 'check' failed
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4355>
