[postgis-tickets] r17357 - Pre-emptively drop functions w/ changed signatures
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 25 10:39:09 PDT 2019
Author: pramsey
Date: 2019-03-25 10:39:09 -0700 (Mon, 25 Mar 2019)
New Revision: 17357
trunk/postgis/postgis_drop_before.sql
References #4345
Modified: trunk/postgis/postgis_drop_before.sql
--- trunk/postgis/postgis_drop_before.sql 2019-03-22 17:04:56 UTC (rev 17356)
+++ trunk/postgis/postgis_drop_before.sql 2019-03-25 17:39:09 UTC (rev 17357)
@@ -67,6 +67,13 @@
DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8);
DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8,boolean);
+-- Going from un-named to named arguments
+DROP FUNCTION _st_linecrossingdirection(geometry,geometry);
+DROP FUNCTION _st_orderingequals(geometry,geometry);
+DROP FUNCTION st_orderingequals(geometry,geometry);
+DROP FUNCTION st_askml(geometry, integer);
+DROP FUNCTION st_buffer(geometry, double precision);
-- Old signatures for protobuf related functions improved in 2.4.0 RC/final
DROP AGGREGATE IF EXISTS ST_AsMVT(text, int4, text, anyelement);
DROP FUNCTION IF EXISTS ST_AsMVTGeom(geom geometry, bounds box2d, extent int4, buffer int4, clip_geom bool);
