[postgis-tickets] [PostGIS] #4359: FAIL: upgrade 2.5.0--3.0.0dev
PostGIS trac at osgeo.org
Thu Mar 28 09:41:02 PDT 2019
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 As reported by our good bot Dronie here:
 https://dronie.osgeo.org/postgis/postgis/184/1/2 (hit "show 250 more
 lines" on top a few times) our upgrades fail due to:
 ERROR: function st_distance(geography, geography) is not unique at
 character 15
 It looks like the upgrade process left some old signature around ?
 Did anyone add a default ?
 A nice view on build history is here:
 https://git.osgeo.org/gitea/postgis/postgis/commits/branch/svn-trunk
 From that page the last spot success was on r17294 (although more recent
 failures may have been due to other reasons)
 You can reproduce the failure locally using the
 utils/check_all_upgrades.sh script (and you could consider updating it to
 support a switch to make it stop on first failure, for easier debugging)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4359>
