[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-54-gfed776a
Fri Apr 17 06:09:49 PDT 2020
the project "PostGIS".
       via  fed776a1574fb652eb88f9919c2ff171b4e711a8 (commit)
      from  8970075ee6cfdf7390b58b2fbb7c3f1bbfbbc234 (commit)
revisions in full, below.
commit fed776a1574fb652eb88f9919c2ff171b4e711a8
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Apr 17 15:09:11 2020 +0200
    Raster cu_tester: Move cu_error_msg declaration to the source file
    References #4667
diff --git a/raster/test/cunit/cu_tester.c b/raster/test/cunit/cu_tester.c
index a75504f..e362323 100644
--- a/raster/test/cunit/cu_tester.c
+++ b/raster/test/cunit/cu_tester.c
@@ -14,6 +14,8 @@
 #include "CUnit/Basic.h"
 #include "cu_tester.h"
+char cu_error_msg[MAX_CUNIT_MSG_LENGTH + 1] = {0};
 /* Internal funcs */
 static void
 cu_error_reporter(const char *fmt, va_list ap);
diff --git a/raster/test/cunit/cu_tester.h b/raster/test/cunit/cu_tester.h
index abefc7f..a166f03 100644
--- a/raster/test/cunit/cu_tester.h
+++ b/raster/test/cunit/cu_tester.h
@@ -21,7 +21,7 @@
 #define PG_ADD_TEST(suite, testfunc) CU_add_test(suite, #testfunc, testfunc)
 /* Contains the most recent error message generated by rterror. */
-char cu_error_msg[MAX_CUNIT_MSG_LENGTH+1];
+extern char cu_error_msg[];
 /* Resets cu_error_msg back to blank. */
 void cu_error_msg_reset(void);
Summary of changes:
 raster/test/cunit/cu_tester.c | 2 ++
 raster/test/cunit/cu_tester.h | 2 +-
 2 files changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
