[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-77-g4643f92
git at osgeo.org
git at osgeo.org
Fri Apr 24 16:58:49 PDT 2020
the project "PostGIS".
via 4643f9284d7d7d26e844413c73bc7c4b0732025b (commit)
from 0696fa46699875fe43708d78602244fd6f257ee4 (commit)
revisions in full, below.
commit 4643f9284d7d7d26e844413c73bc7c4b0732025b
Author: Regina Obe <lr at pcorp.us>
Date: Fri Apr 24 19:58:41 2020 -0400
Fix typos noted by Andreas Schild and Jürgen E. Fischer
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index ee306f1..a3e48aa 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -879,7 +879,7 @@ SELECT ST_ConcaveHull(ST_GeomFromText('MULTILINESTRING((106 164,30 112,74 70,82
geometry that encloses all geometries in the input.</para>
<para>In the general case the convex hull is a Polygon.
- The convext hull of two or more collinear points is a two-point LineString.
+ The convex hull of two or more collinear points is a two-point LineString.
The convex hull of one or more identical points is a Point.</para>
<para>It is usually used with Multi* and GeometryCollections.
@@ -3046,11 +3046,11 @@ FROM (SELECT 'POLYGON((0 0, 8 8, 0 16, 0 0))'::geometry geom) As foo;
geometry will be returned. In a geometry collection
geometries without enough points will just be left out silently. If </para>
<para>This function is mainly intended to be used in conjunction with ST_SetEffectiveArea. ST_EffectiveArea sets the effective area
- of a vertex in it's m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
+ of a vertex in its m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
- <note><para>There is a difference in what ST_SimplifyVW returns when not enough points meets the creterias compared to ST_FilterByM.
+ <note><para>There is a difference in what ST_SimplifyVW returns when not enough points meet the criteria compared to ST_FilterByM.
ST_SimplifyVW returns the geometry with enough points while ST_FilterByM returns an empty geometry</para></note>
- <note><para>Note that the retuned geometry might be invalid</para></note>
+ <note><para>Note that the returned geometry might be invalid</para></note>
<note><para>This function returns all dimensions, also the z and m-value</para></note>
<para>Availability: 2.5.0</para>
</refsection>
Summary of changes:
doc/reference_processing.xml | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
