[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-78-gbed18f2
Fri Apr 24 17:02:12 PDT 2020
the project "PostGIS".
       via  bed18f2f012bc3b222abf82c1a510e4b5ccae0a6 (commit)
      from  4643f9284d7d7d26e844413c73bc7c4b0732025b (commit)
revisions in full, below.
commit bed18f2f012bc3b222abf82c1a510e4b5ccae0a6
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 24 20:02:05 2020 -0400
    Fix typos noted by Andreas Schild and Jürgen E. Fischer
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index a3e48aa..0abb148 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -3044,7 +3044,7 @@ FROM (SELECT  'POLYGON((0 0, 8 8, 0 16, 0 0))'::geometry geom) As foo;
 			the max value. If max-value argument is left out only min value is considered. If fourth argument is left out the m-value
 			will not be in the resulting geometry. If resulting geometry have too few vertex points left for its geometry type an empty
 			geometry will be returned. In a geometry collection
-			geometries without enough points will just be left out silently. If </para>
+			geometries without enough points will just be left out silently.</para>
 		<para>This function is mainly intended to be used in conjunction with ST_SetEffectiveArea. ST_EffectiveArea sets the effective area
 			of a vertex in its m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
Summary of changes:
 doc/reference_processing.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
