[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-145-g6700df0
Fri Jul 3 17:10:53 PDT 2020
the project "PostGIS".
       via  6700df0e2db7965458b36f973d0216ce1cada762 (commit)
      from  50796cc1ae7b77ec0af102c72cd7a365c0f04cd5 (commit)
revisions in full, below.
commit 6700df0e2db7965458b36f973d0216ce1cada762
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 3 20:10:44 2020 -0400
    add partitions to populate_geometry_columns consideration references #4714 for PostGIS 3.1.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9b662c8..92d685d 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1999,7 +1999,7 @@ BEGIN
 		 pg_attribute a,
 		 pg_type t,
 		 pg_namespace n
-	WHERE c.relkind IN('r','v','f')
+	WHERE c.relkind IN('r','v','f', 'p')
 		AND t.typname = 'geometry'
 		AND a.attisdropped = false
 		AND a.atttypid = t.oid
@@ -2016,7 +2016,7 @@ BEGIN
 			 pg_attribute a,
 			 pg_type t,
 			 pg_namespace n
-		WHERE c.relkind IN( 'r', 'f')
+		WHERE c.relkind IN( 'r', 'f', 'p')
@@ -2082,12 +2082,12 @@ BEGIN
 	-- Iterate through all geometry columns in this table
 	FOR gcs IN
-	SELECT n.nspname, c.relname, a.attname
+	SELECT n.nspname, c.relname, a.attname, c.relkind
 		FROM pg_class c,
 			 pg_attribute a,
 			 pg_type t,
 			 pg_namespace n
-		WHERE c.relkind IN('r', 'f')
+		WHERE c.relkind IN('r', 'f', 'p')
@@ -2103,7 +2103,7 @@ BEGIN
         -- Find the srid, coord_dimension, and type of current geometry
         -- in geometry_columns -- which is now a view
-        SELECT type, srid, coord_dimension INTO gc_old
+        SELECT type, srid, coord_dimension, gcs.relkind INTO gc_old
             FROM geometry_columns
             WHERE f_table_schema = gcs.nspname AND f_table_name = gcs.relname AND f_geometry_column = gcs.attname;
Summary of changes:
 postgis/postgis.sql.in | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
