[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-146-g1fab20d
git at osgeo.org
git at osgeo.org
Sun Jul 5 14:54:49 PDT 2020
the project "PostGIS".
via 1fab20d016044103a66fa9b29ec5bf2f358fc580 (commit)
from 6700df0e2db7965458b36f973d0216ce1cada762 (commit)
revisions in full, below.
commit 1fab20d016044103a66fa9b29ec5bf2f358fc580
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 27 23:41:24 2020 +0300
Support for 3D in K-Means.
Closes #4710.
diff --git a/NEWS b/NEWS
index 00f7550..6c3d614 100644
--- a/NEWS
+++ b/NEWS
@@ -9,7 +9,7 @@ Only tickets not included in 3.1.0alpha1
* New features *
- #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
- #4687, Expose GEOS MaximumInscribedCircle (Paul Ramsey)
+ - #4710, ST_ClusterKMeans now works with 3D geometries (Darafei Praliaskouski)
* Enhancements *
- #4675, topology.GetRingEdges now implemented in C (Sandro Santilli)
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index a33fdd5..1ae50b3 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -233,8 +233,9 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
<para>Returns 2D distance based
<ulink url="https://en.wikipedia.org/wiki/K-means_clustering">K-means</ulink>
cluster number for each input geometry. The distance used for clustering is the
- distance between the centroids of the geometries.
+ distance between the centroids for 2D geometries, and distance between bounding box centers for 3D geometries.
</para>
+ <para>Enhanced: 3.1.0 Support for 3D geometries</para>
<para>Availability: 2.3.0</para>
</refsection>
@@ -245,7 +246,7 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
SELECT lpad((row_number() over())::text,3,'0') As parcel_id, geom,
('{residential, commercial}'::text[])[1 + mod(row_number()OVER(),2)] As type
FROM
- ST_Subdivide(ST_Buffer('LINESTRING(40 100, 98 100, 100 150, 60 90)'::geometry,
+ ST_Subdivide(ST_Buffer('SRID=3857;LINESTRING(40 100, 98 100, 100 150, 60 90)'::geometry,
40, 'endcap=square'),12) As geom;
</programlisting>
@@ -306,6 +307,27 @@ FROM parcels;
2 | 006 | residential
(7 rows)</programlisting>
+ <programlisting> -- Clustering points around antimeridian can be done in 3D XYZ CRS, EPSG:4978:
+SELECT ST_ClusterKMeans(ST_Transform(ST_Force3D(geom), 4978), 3) over () AS cid, parcel_id, type
+FROM parcels;
+-- result
+│ cid │ parcel_id │ type │
+│ 1 │ 001 │ commercial │
+│ 2 │ 002 │ residential │
+│ 0 │ 003 │ commercial │
+│ 1 │ 004 │ residential │
+│ 0 │ 005 │ commercial │
+│ 2 │ 006 │ residential │
+│ 0 │ 007 │ commercial │
+(7 rows)
+</programlisting>
</refsection>
<refsection>
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index cdd1f37..1578a2e 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1726,7 +1726,7 @@ static void test_kmeans(void)
- r = lwgeom_cluster_2d_kmeans((const LWGEOM **)geoms, N, num_clusters);
+ r = lwgeom_cluster_kmeans((const LWGEOM **)geoms, N, num_clusters);
// for (i = 0; i < k; i++)
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 7c573b5..59a94ce 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2512,7 +2512,7 @@ LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double toleranc
* @param ngeoms the number of elements in the array
* @param k the number of clusters to calculate
-int * lwgeom_cluster_2d_kmeans(const LWGEOM **geoms, uint32_t ngeoms, uint32_t k);
+int * lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t ngeoms, uint32_t k);
#include "lwinline.h"
diff --git a/liblwgeom/lwinline.h b/liblwgeom/lwinline.h
index 880b51d..c3d4366 100644
--- a/liblwgeom/lwinline.h
+++ b/liblwgeom/lwinline.h
@@ -40,6 +40,16 @@ distance2d_sqr_pt_pt(const POINT2D *p1, const POINT2D *p2)
return hside * hside + vside * vside;
+inline static double
+distance3d_sqr_pt_pt(const POINT3D *p1, const POINT3D *p2)
+ double hside = p2->x - p1->x;
+ double vside = p2->y - p1->y;
+ double zside = p2->z - p1->z;
+ return hside * hside + vside * vside + zside * zside;
* Size of point represeneted in the POINTARRAY
* 16 for 2d, 24 for 3d, 32 for 4d
@@ -94,7 +104,7 @@ getPoint2d_cp(const POINTARRAY *pa, uint32_t n)
- * Returns a POINT2D pointer into the POINTARRAY serialized_ptlist,
+ * Returns a POINT3D pointer into the POINTARRAY serialized_ptlist,
* suitable for reading from. This is very high performance
* and declared const because you aren't allowed to muck with the
* values, only read them.
@@ -106,7 +116,7 @@ getPoint3d_cp(const POINTARRAY *pa, uint32_t n)
+ * Returns a POINT4D pointer into the POINTARRAY serialized_ptlist,
diff --git a/liblwgeom/lwkmeans.c b/liblwgeom/lwkmeans.c
index 8a4931a..bdb244a 100644
--- a/liblwgeom/lwkmeans.c
+++ b/liblwgeom/lwkmeans.c
@@ -1,6 +1,6 @@
- * Copyright (c) 2018, Darafei Praliaskouski <me at komzpa.net>
+ * Copyright (c) 2018-2020, Darafei Praliaskouski <me at komzpa.net>
* Copyright (c) 2016, Paul Ramsey <pramsey at cleverelephant.ca>
@@ -19,33 +19,23 @@
#define KMEANS_MAX_ITERATIONS 1000
-static void
-update_r(POINT2D** objs, int* clusters, uint32_t n, POINT2D** centers, uint32_t k)
+static uint8_t
+update_r(POINT3D *objs, int *clusters, uint32_t n, POINT3D *centers, uint32_t k)
- POINT2D* obj;
- unsigned int i;
- double distance, curr_distance;
- uint32_t cluster, curr_cluster;
+ uint8_t converged = LW_TRUE;
- for (i = 0; i < n; i++)
+ for (uint32_t i = 0; i < n; i++)
- obj = objs[i];
- /* Don't try to cluster NULL objects, just add them to the "unclusterable cluster" */
- if (!obj)
- clusters[i] = KMEANS_NULL_CLUSTER;
- continue;
+ POINT3D obj = objs[i];
/* Initialize with distance to first cluster */
- curr_distance = distance2d_sqr_pt_pt(obj, centers[0]);
- curr_cluster = 0;
+ double curr_distance = distance3d_sqr_pt_pt(&obj, ¢ers[0]);
+ int curr_cluster = 0;
/* Check all other cluster centers and find the nearest */
- for (cluster = 1; cluster < k; cluster++)
+ for (uint32_t cluster = 1; cluster < k; cluster++)
- distance = distance2d_sqr_pt_pt(obj, centers[cluster]);
+ double distance = distance3d_sqr_pt_pt(&obj, ¢ers[cluster]);
if (distance < curr_distance)
curr_distance = distance;
@@ -54,81 +44,63 @@ update_r(POINT2D** objs, int* clusters, uint32_t n, POINT2D** centers, uint32_t
/* Store the nearest cluster this object is in */
- clusters[i] = (int) curr_cluster;
+ if (clusters[i] != (int)curr_cluster)
+ converged = LW_FALSE;
+ clusters[i] = (int)curr_cluster;
+ return converged;
static void
-update_means(POINT2D** objs, int* clusters, uint32_t n, POINT2D** centers, uint32_t* weights, uint32_t k)
+update_means(POINT3D *objs, int *clusters, uint32_t n, POINT3D *centers, uint32_t *weights, uint32_t k)
- uint32_t i;
- int cluster;
memset(weights, 0, sizeof(uint32_t) * k);
- for (i = 0; i < k; i++)
+ memset(centers, 0, sizeof(POINT3D) * k);
- centers[i]->x = 0.0;
- centers[i]->y = 0.0;
- cluster = clusters[i];
- if (cluster != KMEANS_NULL_CLUSTER)
- centers[cluster]->x += objs[i]->x;
- centers[cluster]->y += objs[i]->y;
- weights[cluster] += 1;
+ int cluster = clusters[i];
+ centers[cluster].x += objs[i].x;
+ centers[cluster].y += objs[i].y;
+ centers[cluster].z += objs[i].z;
+ weights[cluster] += 1;
+ for (uint32_t i = 0; i < k; i++)
if (weights[i])
- centers[i]->x /= weights[i];
- centers[i]->y /= weights[i];
+ centers[i].x /= weights[i];
+ centers[i].y /= weights[i];
+ centers[i].z /= weights[i];
-static int
-kmeans(POINT2D** objs, int* clusters, uint32_t n, POINT2D** centers, uint32_t k)
+static uint8_t
+kmeans(POINT3D *objs, int *clusters, uint32_t n, POINT3D *centers, uint32_t k)
- uint32_t i = 0;
- int* clusters_last;
- int converged = LW_FALSE;
- size_t clusters_sz = sizeof(int) * n;
- uint32_t* weights;
+ uint8_t converged = LW_FALSE;
+ uint32_t *weights = lwalloc(sizeof(uint32_t) * k);
- weights = lwalloc(sizeof(int) * k);
- /* previous cluster state array */
- clusters_last = lwalloc(clusters_sz);
- for (i = 0; i < KMEANS_MAX_ITERATIONS && !converged; i++)
+ for (uint32_t i = 0; i < KMEANS_MAX_ITERATIONS; i++)
LW_ON_INTERRUPT(break);
- /* store the previous state of the clustering */
- memcpy(clusters_last, clusters, clusters_sz);
- update_r(objs, clusters, n, centers, k);
+ converged = update_r(objs, clusters, n, centers, k);
+ if (converged)
+ break;
update_means(objs, clusters, n, centers, weights, k);
- /* if all the cluster numbers are unchanged, we are at a stable solution */
- converged = memcmp(clusters_last, clusters, clusters_sz) == 0;
- lwfree(clusters_last);
lwfree(weights);
if (!converged)
- lwerror("%s did not converge after %d iterations", __func__, i);
+ lwerror("%s did not converge after %d iterations", __func__, KMEANS_MAX_ITERATIONS);
return converged;
static void
-kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw, uint32_t k)
+kmeans_init(POINT3D *objs, uint32_t n, POINT3D *centers, uint32_t k)
- double* distances;
+ double *distances;
uint32_t p1 = 0, p2 = 0;
uint32_t i, j;
uint32_t duplicate_count = 1; /* a point is a duplicate of itself */
@@ -141,20 +113,9 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
/* k >= 2: find two distant points greedily */
for (i = 1; i < n; i++)
- /* skip null */
- if (!objs[i]) continue;
- /* reinit if first element happened to be null */
- if (!objs[p1] && !objs[p2])
- p1 = i;
- p2 = i;
- continue;
/* if we found a larger distance, replace our choice */
- dst_p1 = distance2d_sqr_pt_pt(objs[i], objs[p1]);
- dst_p2 = distance2d_sqr_pt_pt(objs[i], objs[p2]);
+ dst_p1 = distance3d_sqr_pt_pt(&objs[i], &objs[p1]);
+ dst_p2 = distance3d_sqr_pt_pt(&objs[i], &objs[p2]);
if ((dst_p1 > max_dst) || (dst_p2 > max_dst))
if (dst_p1 > dst_p2)
@@ -168,7 +129,8 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
p1 = i;
- if ((dst_p1 == 0) || (dst_p2 == 0)) duplicate_count++;
+ if ((dst_p1 == 0) || (dst_p2 == 0))
+ duplicate_count++;
if (duplicate_count > 1)
lwnotice(
@@ -177,13 +139,11 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
duplicate_count);
/* by now two points should be found and non-same */
- assert(p1 != p2 && objs[p1] && objs[p2] && max_dst >= 0);
+ assert(p1 != p2 && max_dst >= 0);
/* accept these two points */
- centers_raw[0] = *((POINT2D *)objs[p1]);
- centers[0] = &(centers_raw[0]);
- centers_raw[1] = *((POINT2D *)objs[p2]);
- centers[1] = &(centers_raw[1]);
+ centers[0] = objs[p1];
+ centers[1] = objs[p2];
if (k > 2)
@@ -192,12 +152,7 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
/* initialize array with distance to first object */
for (j = 0; j < n; j++)
- if (objs[j])
- distances[j] = distance2d_sqr_pt_pt(objs[j], centers[0]);
- else
- distances[j] = -1;
+ distances[j] = distance3d_sqr_pt_pt(&objs[j], ¢ers[0]);
distances[p1] = -1;
distances[p2] = -1;
@@ -211,10 +166,11 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
/* empty objs and accepted clusters are already marked with distance = -1 */
- if (distances[j] < 0) continue;
+ if (distances[j] < 0)
+ continue;
/* update minimal distance with previosuly accepted cluster */
- current_distance = distance2d_sqr_pt_pt(objs[j], centers[i - 1]);
+ current_distance = distance3d_sqr_pt_pt(&objs[j], ¢ers[i - 1]);
if (current_distance < distances[j])
distances[j] = current_distance;
@@ -233,33 +189,17 @@ kmeans_init(POINT2D **objs, uint32_t n, POINT2D **centers, POINT2D *centers_raw,
distances[candidate_center] = -1;
/* Copy the point coordinates into the initial centers array
* Centers array is an array of pointers to points, not an array of points */
- centers_raw[i] = *((POINT2D *)objs[candidate_center]);
- centers[i] = &(centers_raw[i]);
+ centers[i] = objs[candidate_center];
lwfree(distances);
-int*
-lwgeom_cluster_2d_kmeans(const LWGEOM** geoms, uint32_t n, uint32_t k)
+int *
+lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t n, uint32_t k)
- uint32_t i;
- uint32_t num_centroids = 0;
uint32_t num_non_empty = 0;
- LWGEOM** centroids;
- POINT2D* centers_raw;
- const POINT2D* cp;
- int result = LW_FALSE;
- /* An array of objects to be analyzed.
- * All NULL values will be returned in the KMEANS_NULL_CLUSTER. */
- POINT2D** objs;
- /* An array of centers for the algorithm. */
- POINT2D** centers;
- /* Array to fill in with cluster numbers. */
- int* clusters;
+ uint8_t result = LW_FALSE;
assert(k > 0);
assert(n > 0);
@@ -267,79 +207,116 @@ lwgeom_cluster_2d_kmeans(const LWGEOM** geoms, uint32_t n, uint32_t k)
if (n < k)
- lwerror("%s: number of geometries is less than the number of clusters requested, not all clusters will get data", __func__);
+ lwerror(
+ "%s: number of geometries is less than the number of clusters requested, not all clusters will get data",
+ __func__);
k = n;
- /* We'll hold the temporary centroid objects here */
- centroids = lwalloc(sizeof(LWGEOM*) * n);
- memset(centroids, 0, sizeof(LWGEOM*) * n);
- /* The vector of cluster means. We have to allocate a chunk of memory for these because we'll be mutating them
- * in the kmeans algorithm */
- centers_raw = lwalloc(sizeof(POINT2D) * k);
- memset(centers_raw, 0, sizeof(POINT2D) * k);
+ /* An array of objects to be analyzed. */
+ POINT3D *objs = lwalloc(sizeof(POINT3D) * n);
- /* K-means configuration setup */
- objs = lwalloc(sizeof(POINT2D*) * n);
- clusters = lwalloc(sizeof(int) * n);
- centers = lwalloc(sizeof(POINT2D*) * k);
+ /* Array to mark unclusterable objects. Will be returned as KMEANS_NULL_CLUSTER. */
+ uint8_t *geom_valid = lwalloc(sizeof(uint8_t) * n);
+ memset(geom_valid, 0, sizeof(uint8_t) * n);
- /* Clean the memory */
- memset(objs, 0, sizeof(POINT2D*) * n);
+ /* Array to fill in with cluster numbers. */
+ int *clusters = lwalloc(sizeof(int) * n);
memset(clusters, 0, sizeof(int) * n);
- memset(centers, 0, sizeof(POINT2D*) * k);
+ /* An array of clusters centers for the algorithm. */
+ POINT3D *centers = lwalloc(sizeof(POINT3D) * k);
/* Prepare the list of object pointers for K-means */
- const LWGEOM* geom = geoms[i];
- LWPOINT* lwpoint;
+ const LWGEOM *geom = geoms[i];
+ POINT3D out = {0, 0, 0};
- /* Null/empty geometries get a NULL pointer, set earlier with memset */
- if ((!geom) || lwgeom_is_empty(geom)) continue;
+ /* Null/empty geometries get geom_valid=LW_FALSE set earlier with memset */
+ if ((!geom) || lwgeom_is_empty(geom))
+ continue;
/* If the input is a point, use its coordinates */
- /* If its not a point, convert it to one via centroid */
- if (lwgeom_get_type(geom) != POINTTYPE)
+ if (lwgeom_get_type(geom) == POINTTYPE)
+ out.x = lwpoint_get_x(lwgeom_as_lwpoint(geom));
+ out.y = lwpoint_get_y(lwgeom_as_lwpoint(geom));
+ if (lwgeom_has_z(geom))
+ out.z = lwpoint_get_z(lwgeom_as_lwpoint(geom));
+ else if (!lwgeom_has_z(geom))
- LWGEOM* centroid = lwgeom_centroid(geom);
- if ((!centroid)) continue;
+ /* For 2D, we can take a centroid*/
+ LWGEOM *centroid = lwgeom_centroid(geom);
+ if (!centroid)
+ continue;
if (lwgeom_is_empty(centroid))
lwgeom_free(centroid);
continue;
- centroids[num_centroids++] = centroid;
- lwpoint = lwgeom_as_lwpoint(centroid);
+ out.x = lwpoint_get_x(lwgeom_as_lwpoint(centroid));
+ out.y = lwpoint_get_y(lwgeom_as_lwpoint(centroid));
+ lwgeom_free(centroid);
else
- lwpoint = lwgeom_as_lwpoint(geom);
- /* Store a pointer to the POINT2D we are interested in */
- cp = getPoint2d_cp(lwpoint->point, 0);
- objs[i] = (POINT2D*)cp;
- num_non_empty++;
+ /* For 3D non-point, we can have a box center */
+ const GBOX *box = lwgeom_get_bbox(geom);
+ if (!gbox_is_valid(box))
+ continue;
+ out.x = (box->xmax + box->xmin) / 2;
+ out.y = (box->ymax + box->ymin) / 2;
+ out.z = (box->zmax + box->zmin) / 2;
+ geom_valid[i] = LW_TRUE;
+ objs[num_non_empty++] = out;
if (num_non_empty < k)
- lwnotice("%s: number of non-empty geometries is less than the number of clusters requested, not all clusters will get data", __func__);
+ lwnotice(
+ "%s: number of non-empty geometries (%d) is less than the number of clusters (%d) requested, not all clusters will get data",
+ __func__,
+ num_non_empty,
+ k);
k = num_non_empty;
if (k > 1)
- kmeans_init(objs, n, centers, centers_raw, k);
- result = kmeans(objs, clusters, n, centers, k);
+ int *clusters_dense = lwalloc(sizeof(int) * num_non_empty);
+ memset(clusters_dense, 0, sizeof(int) * num_non_empty);
+ kmeans_init(objs, num_non_empty, centers, k);
+ result = kmeans(objs, clusters_dense, num_non_empty, centers, k);
+ if (result)
+ uint32_t d = 0;
+ if (geom_valid[i])
+ clusters[i] = clusters_dense[d++];
+ else
+ clusters[i] = KMEANS_NULL_CLUSTER;
+ lwfree(clusters_dense);
+ else if (k == 0)
+ /* k=0: everything is unclusterable */
+ result = LW_TRUE;
else
- /* k=0: everything is unclusterable
- * k=1: mark up NULL and non-NULL */
+ /* k=1: mark up NULL and non-NULL */
- if (k == 0 || !objs[i])
+ if (!geom_valid[i])
else
clusters[i] = 0;
@@ -350,11 +327,11 @@ lwgeom_cluster_2d_kmeans(const LWGEOM** geoms, uint32_t n, uint32_t k)
/* Before error handling, might as well clean up all the inputs */
lwfree(objs);
lwfree(centers);
- lwfree(centers_raw);
- lwfree(centroids);
+ lwfree(geom_valid);
/* Good result */
- if (result) return clusters;
+ if (result)
+ return clusters;
/* Bad result, not going to need the answer */
lwfree(clusters);
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index fe36875..107590b 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -232,7 +232,7 @@ Datum ST_ClusterKMeans(PG_FUNCTION_ARGS)
/* Calculate k-means on the list! */
- r = lwgeom_cluster_2d_kmeans((const LWGEOM **)geoms, N, k);
+ r = lwgeom_cluster_kmeans((const LWGEOM **)geoms, N, k);
/* Clean up */
for (i = 0; i < N; i++)
diff --git a/regress/core/cluster.sql b/regress/core/cluster.sql
index d8ed0a8..7358222 100644
--- a/regress/core/cluster.sql
+++ b/regress/core/cluster.sql
@@ -44,7 +44,7 @@ SELECT '#3612b', ST_ClusterDBSCAN(ST_Point(1,1), 20.1, 5) OVER();
-- ST_ClusterKMeans
-select '#4100a', count(distinct result) from (SELECT ST_ClusterKMeans(foo1.the_geom, 3)OVER() As result
+select '#4100a', count(distinct result) from (SELECT ST_ClusterKMeans(foo1.the_geom, 3) OVER() As result
FROM ((SELECT ST_Collect(geom) As the_geom
FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1))') ) ) As g(geom) CROSS JOIN generate_series(1,3) As i GROUP BY i )) As foo1 LIMIT 10) kmeans;
@@ -60,3 +60,15 @@ select '#4101a', count(distinct result) from (SELECT ST_ClusterKMeans(foo1.the_g
UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom ) ) As foo1 LIMIT 10) kmeans;
select '#4101b', count(distinct cid) from (select ST_ClusterKMeans(geom,2) over () as cid from (values ('POINT EMPTY'::geometry), ('POINT EMPTY')) g(geom)) kmeans;
+select '3d_support-1', count(distinct cid) from (select ST_ClusterKMeans(geom,2) over () as cid from (values ('POINT(0 0 1)'::geometry), ('POINT(0 0 5)'), ('POINT(0 0 7)')) g(geom)) kmeans;
+select '3d_support-2', count(distinct cid) from (select ST_ClusterKMeans(geom,2) over () as cid from (values ('LINESTRING(0 0 1, 0 0 -1)'::geometry), ('POINT(0 0 5)'), ('POINT(0 0 7)')) g(geom)) kmeans;
+select '3d_support-3', count(distinct cid) from (select ST_ClusterKMeans(geom,2) over () as cid from (values ('LINESTRING(0 0, 0 0)'::geometry), ('POINT(0 0)'), ('POINT(0 0)')) g(geom)) kmeans;
+-- check that null and empty is handled in the clustering
+select '#4071', count(distinct a), count(distinct b), count(distinct c) from
+(select
+ ST_ClusterKMeans(geom, 1) over () a,
+ ST_ClusterKMeans(geom, 2) over () b,
+ ST_ClusterKMeans(geom, 3) over () c
+from (values (null::geometry), ('POINT(1 1)'), ('POINT EMPTY'), ('POINT(0 0)'), ('POINT(4 4)')) as g (geom)) z;
diff --git a/regress/core/cluster_expected b/regress/core/cluster_expected
index cb7ac91..287125b 100644
--- a/regress/core/cluster_expected
+++ b/regress/core/cluster_expected
@@ -34,7 +34,12 @@ NOTICE: kmeans_init: there are at least 3 duplicate inputs, number of output cl
#4100a|1
NOTICE: kmeans_init: there are at least 2 duplicate inputs, number of output clusters may be less than you requested
#4100b|1
-NOTICE: lwgeom_cluster_2d_kmeans: number of non-empty geometries is less than the number of clusters requested, not all clusters will get data
+NOTICE: lwgeom_cluster_kmeans: number of non-empty geometries (0) is less than the number of clusters (3) requested, not all clusters will get data
#4101a|1
+NOTICE: lwgeom_cluster_kmeans: number of non-empty geometries (0) is less than the number of clusters (2) requested, not all clusters will get data
#4101b|1
+3d_support-1|2
+3d_support-2|2
+NOTICE: kmeans_init: there are at least 3 duplicate inputs, number of output clusters may be less than you requested
+3d_support-3|1
+#4071|2|3|4
diff --git a/regress/core/lwgeom_regress.sql b/regress/core/lwgeom_regress.sql
index 988b81e..e95818d 100644
--- a/regress/core/lwgeom_regress.sql
+++ b/regress/core/lwgeom_regress.sql
@@ -219,14 +219,6 @@ group by cid
order by count(*)
limit 1;
--- check that null and empty is handled in the clustering
-select '#4071', count(distinct a), count(distinct b), count(distinct c) from
-(select
- ST_ClusterKMeans(geom, 1) over () a,
- ST_ClusterKMeans(geom, 2) over () b,
- ST_ClusterKMeans(geom, 3) over () c
-from (values (null::geometry), ('POINT(1 1)'), ('POINT EMPTY'), ('POINT(0 0)'), ('POINT(4 4)')) as g (geom)) z;
-- typmod checks
select 'typmod_point_4326', geometry_typmod_out(geometry_typmod_in('{Point,4326}'));
select 'typmod_point_0', geometry_typmod_out(geometry_typmod_in('{Point,0}'));
diff --git a/regress/core/lwgeom_regress_expected b/regress/core/lwgeom_regress_expected
index dd88331..8dfd405 100644
--- a/regress/core/lwgeom_regress_expected
+++ b/regress/core/lwgeom_regress_expected
@@ -43,7 +43,6 @@ ERROR: Empty geometry
ST_Angle_2_lines|4.712389
#3965|25|25
#3971|t
-#4071|2|3|4
typmod_point_4326|(Point,4326)
typmod_point_0|(Point)
NOTICE: SRID value -1 converted to the officially unknown SRID value 0
Summary of changes:
NEWS | 2 +-
doc/reference_cluster.xml | 26 +++-
liblwgeom/cunit/cu_algorithm.c | 2 +-
liblwgeom/liblwgeom.h.in | 2 +-
liblwgeom/lwinline.h | 14 +-
liblwgeom/lwkmeans.c | 291 ++++++++++++++++-------------------
postgis/lwgeom_window.c | 2 +-
regress/core/cluster.sql | 14 +-
regress/core/cluster_expected | 9 +-
regress/core/lwgeom_regress.sql | 8 -
regress/core/lwgeom_regress_expected | 1 -
11 files changed, 194 insertions(+), 177 deletions(-)
hooks/post-receive
