[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-150-g3f60648
Mon Jul 6 04:31:50 PDT 2020
the project "PostGIS".
       via  3f60648eb09d50d082dad352f9bcfbae775f964d (commit)
       via  e4a3bd6e811b172907fe02e78d6c397c07c5473d (commit)
      from  28d3e83bcb1820bb4752d38530cd319c9424003e (commit)
revisions in full, below.
commit 3f60648eb09d50d082dad352f9bcfbae775f964d
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Jun 22 12:42:02 2020 +0200
    Configure: Default to -lproj in all cases
    References #4716
    Closes https://github.com/postgis/postgis/pull/567
diff --git a/NEWS b/NEWS
index 6c3d614..df59f40 100644
--- a/NEWS
+++ b/NEWS
@@ -29,6 +29,7 @@ Only tickets not included in 3.1.0alpha1
   - #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
   - #4670, ST_AddPoint: Fix bug when a positive position is requested (Raúl Marín)
   - #4699, crash on null input to ST_Union(raster, otherarg) (Jaime Casanova, 2ndQuadrant)
+  - #4716, Fix several issues with pkg-config in the configure script (Raúl Marín)
 PostGIS 3.1.0alpha1
 2020/02/01
diff --git a/configure.ac b/configure.ac
index 590cf7c..5398ae0 100644
--- a/configure.ac
+++ b/configure.ac
@@ -864,15 +864,18 @@ if test ! "x$PROJDIR" = "x"; then
 		fi
 	fi
 elif test ! -z "$PKG_CONFIG"; then
-        dnl To keep compatibility with PROJ pre 4.8, default to lproj if not found
+	dnl To keep compatibility with PROJ pre 4.8, default to lproj if not found
 	PKG_CHECK_MODULES([PROJ], [proj],
-                PROJ_CPPFLAGS="$PROJ_CFLAGS"
-                PROJ_LDFLAGS="$PROJ_LIBS"
-                PROJ_LDFLAGS="-lproj"
+			PROJ_CPPFLAGS="$PROJ_CFLAGS"
+			PROJ_LDFLAGS="$PROJ_LIBS"
+			PROJ_LDFLAGS="-lproj"
+else
 fi
commit e4a3bd6e811b172907fe02e78d6c397c07c5473d
Date:   Mon Jun 22 12:42:27 2020 +0200
    Configure: Don't error if json-c is not found with pkg-config
index db8ceb9..590cf7c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -957,7 +957,7 @@ if test "$CHECK_JSON" != "no"; then
                 HAVE_JSON=yes
                 JSON_CPPFLAGS="$JSONC_CFLAGS"
                 JSON_LDFLAGS="$JSONC_LIBS"
+            ], [AC_MSG_WARN("Could not find json-c")])
     fi
     if test "$HAVE_JSON" = "yes"; then
Summary of changes:
 NEWS         |  1 +
 configure.ac | 21 ++++++++++++---------
 2 files changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
