[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.1-26-g2d89dab
git at osgeo.org
git at osgeo.org
Mon Jul 6 04:33:35 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
via 2d89dabd2f2b561fbc0e95b1ed12ee8487ef6271 (commit)
via 9588e3a4f384f7c33e060138c944e39fe5d93ce1 (commit)
from aeea5121b2a99137e67ea4177c8b5d43efcba35d (commit)
revisions in full, below.
commit 2d89dabd2f2b561fbc0e95b1ed12ee8487ef6271
Author: Raúl Marín <git at rmr.ninja>
Date: Mon Jun 22 12:42:02 2020 +0200
Configure: Default to -lproj in all cases
Closes #4716
diff --git a/NEWS b/NEWS
index 1964cbe..39ad4fd 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ PostGIS 3.0.2
- #4670, ST_AddPoint: Fix bug when a positive position is requested (Raúl Marín)
- #4702, Legacy ST_Locate_Between_Measures is wrong (Kaplas80)
- #4699, crash on null input to ST_Union(raster, otherarg) (Jaime Casanova, 2ndQuadrant)
+ - #4716, Fix several issues with pkg-config in the configure script (Raúl Marín)
PostGIS 3.0.1
2020/02/20
diff --git a/configure.ac b/configure.ac
index 1e06773..4f26390 100644
--- a/configure.ac
+++ b/configure.ac
@@ -874,15 +874,18 @@ if test ! "x$PROJDIR" = "x"; then
fi
fi
elif test ! -z "$PKG_CONFIG"; then
- dnl To keep compatibility with PROJ pre 4.8, default to lproj if not found
+ dnl To keep compatibility with PROJ pre 4.8, default to lproj if not found
PKG_CHECK_MODULES([PROJ], [proj],
- PROJ_CPPFLAGS="$PROJ_CFLAGS"
- PROJ_LDFLAGS="$PROJ_LIBS"
- PROJ_LDFLAGS="-lproj"
+ PROJ_CPPFLAGS="$PROJ_CFLAGS"
+ PROJ_LDFLAGS="$PROJ_LIBS"
+ PROJ_LDFLAGS="-lproj"
+else
fi
commit 9588e3a4f384f7c33e060138c944e39fe5d93ce1
Date: Mon Jun 22 12:42:27 2020 +0200
Configure: Don't error if json-c is not found with pkg-config
index c5df08d..1e06773 100644
--- a/configure.ac
+++ b/configure.ac
@@ -967,7 +967,7 @@ if test "$CHECK_JSON" != "no"; then
HAVE_JSON=yes
JSON_CPPFLAGS="$JSONC_CFLAGS"
JSON_LDFLAGS="$JSONC_LIBS"
+ ], [AC_MSG_WARN("Could not find json-c")])
fi
if test "$HAVE_JSON" = "yes"; then
Summary of changes:
NEWS | 1 +
configure.ac | 21 ++++++++++++---------
2 files changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
