[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-151-g17e3e8f
Mon Jul 6 04:35:47 PDT 2020
the project "PostGIS".
       via  17e3e8fd60319f67ce071df3c290e96550c818ed (commit)
      from  3f60648eb09d50d082dad352f9bcfbae775f964d (commit)
revisions in full, below.
commit 17e3e8fd60319f67ce071df3c290e96550c818ed
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Jun 26 17:34:30 2020 +0200
    Travis: Use PG13 as the default target
    Closes #4701
diff --git a/.travis.yml b/.travis.yml
index 678fff5..7e0a658 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -5,16 +5,17 @@ language: c
 env:
   # Use the last stable release to run more tests
-  - tag=pg12-geos37-gdal30-proj611 mode=garden
-  - tag=pg12-geos37-gdal30-proj611 mode=tests
-  - tag=pg12-geos37-gdal30-proj611 mode=debug
-  - tag=pg12-geos37-gdal30-proj611 mode=coverage
-  - tag=pg12-geos37-gdal30-proj611 mode=usan_gcc
-  - tag=pg12-clang-geos37-gdal30-proj611 mode=usan_clang
-  - tag=pg12-geos37-gdal30-proj611 mode=nowagyu
+  - tag=pg13-geos38-gdal31-proj71 mode=garden
+  - tag=pg13-geos38-gdal31-proj71 mode=tests
+  - tag=pg13-geos38-gdal31-proj71 mode=debug
+  - tag=pg13-geos38-gdal31-proj71 mode=coverage
+  - tag=pg13-geos38-gdal31-proj71 mode=usan_gcc
+  - tag=pg13-clang-geos38-gdal31-proj71 mode=usan_clang
+  - tag=pg13-geos38-gdal31-proj71 mode=nowagyu
   # Run tests with different dependency combinations
   - tag=latest mode=tests
+  - tag=pg12-geos37-gdal30-proj611 mode=tests
   - tag=pg11-geos37-gdal24-proj52 mode=tests
   - tag=pg10-geos36-gdal23-proj49 mode=tests
   - tag=pg96-geos36-gdal22-proj49 mode=tests
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index a3126ac..515176f 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -10,7 +10,7 @@ export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 #Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/8/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
+LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
 # Build with Clang and usan flags
Summary of changes:
 .travis.yml                 | 15 ++++++++-------
 ci/travis/run_usan_clang.sh |  2 +-
 2 files changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
