[postgis-tickets] [PostGIS] #4717: upgrading to 3.0.1 from 2.4.4 following docu does not work: "Updating extension postgis from 3.0.1 to 2.4.4" ?!
trac at osgeo.org
Wed Jul 8 02:02:29 PDT 2020
Reporter: tpo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.2
Component: postgis | Version: 3.0.x
Keywords: |
According to
http://postgis.net/docs/manual-3.0/postgis_installation.html#soft_upgrade_extensions
One should upgrade like this:
ALTER EXTENSION postgis UPDATE TO "3.0.2dev";
ALTER EXTENSION postgis_topology UPDATE TO "3.0.2dev";
I am upgrading to 3.0.1 because there do not seem to exist higher version
of postgis than postgresql-11-postgis-3 3.0.1+dfsg-2.pgdg100+1 for Debian
buster at https://apt.postgresql.org.
If I do the above then I get:
psql > ALTER EXTENSION postgis UPDATE TO "3.0.1"; ALTER EXTENSION
postgis_topology UPDATE TO "3.0.1";
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade(); to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
Let's see where we're at:
psql > \dx
List of installed extensions
Name | Version | Schema |
Description
hstore | 1.4 | public | data type for storing sets of
(key, value) pairs
plpgsql | 1.0 | pg_catalog | PL/pgSQL procedural language
postgis | 3.0.1 | public | PostGIS geometry, geography,
and raster spatial types and functions
postgis_topology | 3.0.1 | topology | PostGIS topology spatial types
and functions
(4 rows)
So let us now update, as indicated by the "hint" above:
psql> SELECT postgis_extensions_upgrade();
NOTICE: Updating extension postgis from 3.0.1 to 2.4.4
ERROR: extension "postgis" has no update path from version "3.0.1" to
version "2.4.4"
CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "2.4.4";"
PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
So I'd say there's something broken there.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4717>
