[postgis-tickets] [PostGIS] #4717: upgrading to 3.0.1 from 2.4.4 following docu does not work: "Updating extension postgis from 3.0.1 to 2.4.4" ?!
trac at osgeo.org
Wed Jul 8 02:38:17 PDT 2020
Reporter: tpo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.2
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
> NOTICE: Updating extension postgis from 3.0.1 to 2.4.4
What's broken is that your operating system thinks 2.4.4
is the "default postgis" to be installed (postgis.control
in $(pg_config --sharedir)/extensions/)
Surely postgis_extensions_upgrade() could handle this case
and avoid even *trying* to "upgrade" from newer to older
version, but the underlying problem remains: you seem to
have installed 2.4.4 *after* 3.0.1. Re-installing 3.0.1
should fix this problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4717#comment:1>
