[postgis-tickets] [PostGIS] #4717: upgrading to 3.0.1 from 2.4.4 following docu does not work: "Updating extension postgis from 3.0.1 to 2.4.4" ?!
PostGIS trac at osgeo.org
Wed Jul 8 05:30:07 PDT 2020
  Reporter:  tpo      |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.2
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Comment (by tpo):
 I've reinstalled both the postgresql-10-postgis-3 and
 postgresql-10-postgis-3-scripts packages but the result is exactly the
 same.
 (Note for other people reading this ticket: it's $(pg_config
 --sharedir)/extension/ without the trailing 's' (i.e.
 /usr/share/postgresql/10/extension/).
 Which one would be the file that the "operating system" thinks is the
 "default postgis"? Is it this one:
 /usr/share/postgresql/10/extension/postgis.control
 Note that the packet manager tells me that that file only exists in:
 dpkg -S /usr/share/postgresql/10/extension/postgis.control
 postgresql-10-postgis-2.4-scripts:
 No such file exists inside the postgresql-10-postgis-3-scripts package.
 How does the "operating system" determine, which the "default postgis"
 would be?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4717#comment:2>
