[postgis-tickets] [PostGIS] #4673: [raster] PG 13 / GDAL latest: rt_gdalwarp regress failing
PostGIS trac at osgeo.org
Thu Jul 9 05:35:58 PDT 2020
  Reporter:  Algunenano  |      Owner:  Bborie Park
      Type:  defect      |     Status:  new
  Priority:  high        |  Milestone:  PostGIS 3.1.0
 Component:  raster      |    Version:  master
Resolution:              |   Keywords:
Comment (by robe):
 Not sure this is related, but debbie has been failing for a while at least
 since July 7th (probably earlier but I've she only keeps last 10 runs or
 so) testing GDAL Master (3.2) (I got to flip the version)
  -------------- Dependencies --------------
   GEOS config:          /var/lib/jenkins/workspace/geos/rel-3.9w64/bin
 /geos-config
   GEOS version:         3.9.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-3.1w64/bin
 /gdal-config
   GDAL version:         3.2.0
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.7
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg10w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 10.13
   PROJ4 version:        71
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.10
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1003003
   PCRE support:         no
   Perl:                 /usr/bin/perl
   Wagyu:                yes
 INFO: Self-intersection at or near point 2 -2
 FAILED
     1. cu_raster_geometry.c:296  -
 CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 0,1 -1,0 -1,0 -5,4 -5,5 -5,5
 0,1 0)))")
     2. cu_raster_geometry.c:308  -
 0,1 0),(1 -1,1 -2,2 -2,2 -1,1 -1)))")
     3. cu_raster_geometry.c:321  -
 CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0
 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))")
     4. cu_raster_geometry.c:335  -
 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3
 -4,4 -4,4 -3,3 -3)))")
     5. cu_raster_geometry.c:363  -
 CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -4,2 -4,2 -3,3 -3,3 -4,4 -4,4
 -5,3 -5,1 -5,1 -4)),((1 -4,0 -4,0 -1,1 -1,1 -2,2 -2,2 -3,1 -3,1 -4)),((3
 -2,4 -2,4 -1,5 -1,5 -4,4 -4,4 -3,3 -3,3 -2)),((3 -2,2 -2,2 -1,1 -1,1 0,4
 0,4 -1,3 -1,3 -2)))")
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4673#comment:4>
