[postgis-tickets] [PostGIS] #4673: [raster] PG 13 / GDAL latest: rt_gdalwarp regress failing
trac at osgeo.org
Thu Jul 9 05:37:33 PDT 2020
Reporter: Algunenano | Owner: Bborie Park
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.1.0
Component: raster | Version: master
Resolution: | Keywords:
Comment (by robe):
full raster cunit output for completeness
-------------- Dependencies --------------
GEOS config: /var/lib/jenkins/workspace/geos/rel-3.9w64/bin
/geos-config
GEOS version: 3.9.0dev
GDAL config: /var/lib/jenkins/workspace/gdal/rel-3.1w64/bin
/gdal-config
GDAL version: 3.2.0
SFCGAL config: /usr/bin/sfcgal-config
SFCGAL version: 1.3.7
PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg10w64/bin/pg_config
PostgreSQL version: PostgreSQL 10.13
PROJ4 version: 71
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.10
JSON-C support: yes
protobuf support: yes
protobuf-c version: 1003003
PCRE support: no
Perl: /usr/bin/perl
Wagyu: yes
Suite: pixtype
Test: test_pixtype_size ...passed
Test: test_pixtype_alignment ...passed
Test: test_pixtype_name ...passed
Test: test_pixtype_index_from_name ...passed
Test: test_pixtype_get_min_value ...passed
Test: test_pixtype_compare_clamped_values ...passed
Suite: raster_basics
Test: test_raster_new ...passed
Test: test_raster_empty ...passed
Test: test_raster_metadata ...passed
Test: test_raster_clone ...passed
Test: test_raster_from_band ...passed
Test: test_raster_replace_band ...passed
Suite: band_basics
Test: test_band_metadata ...passed
Test: test_band_pixtype_1BB ...passed
Test: test_band_pixtype_2BUI ...passed
Test: test_band_pixtype_4BUI ...passed
Test: test_band_pixtype_8BUI ...passed
Test: test_band_pixtype_8BSI ...passed
Test: test_band_pixtype_16BUI ...passed
Test: test_band_pixtype_16BSI ...passed
Test: test_band_pixtype_32BUI ...passed
Test: test_band_pixtype_32BSI ...passed
Test: test_band_pixtype_32BF ...passed
Test: test_band_pixtype_64BF ...passed
Test: test_band_get_pixel_line ...WARNING: Limiting returning number
values to 1
WARNING: Attempting to get pixel values with out of range raster
coordinates: (5, 5)
passed
Test: test_band_new_offline_from_path ...passed
Suite: raster_wkb
Test: test_raster_wkb ...SRID value -1 converted to the officially
unknown SRID value 0
SRID value -1 converted to the officially unknown SRID value 0
passed
Suite: gdal
Test: test_gdal_configured ...passed
Test: test_gdal_drivers ...passed
Test: test_gdal_rasterize ...passed
Test: test_gdal_polygonize ...FAILED
1. cu_gdal.c:180 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3 1,3 2,2 2,2
3,1 3,1 6,2 6,2 7,3 7,3 8,5 8,5 6,3 6,3 3,4 3,5 3,5 1,3 1))")
2. cu_gdal.c:196 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0 0,0 9,9 9,9
0,0 0),(6 7,6 8,3 8,3 7,2 7,2 6,1 6,1 3,2 3,2 2,3 2,3 1,6 1,6 2,7 2,7 3,8
3,8 6,7 6,7 7,6 7))")
3. cu_gdal.c:232 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0 0,0 9,9 9,9
4. cu_gdal.c:260 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0 0,0 9,9 9,9
5. cu_gdal.c:264 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3 1,3 2,2 2,2
6. cu_gdal.c:295 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3 1,3 2,2 2,2
7. cu_gdal.c:327 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((3 1,3 2,2 2,2
8. cu_gdal.c:343 - CU_ASSERT_STRING_EQUAL(wkt,"POLYGON((0 0,0 9,9 9,9
Test: test_raster_to_gdal ...Warning 6: PNG driver doesn't support data
type Float64. Only eight bit (Byte) and sixteen bit (UInt16) bands
supported. Defaulting to Byte
passed
Test: test_gdal_to_raster ...passed
Test: test_gdal_warp ...passed
Suite: raster_geometry
Test: test_raster_envelope ...passed
Test: test_raster_envelope_geom ...passed
Test: test_raster_convex_hull ...passed
Test: test_raster_surface ...INFO: Self-intersection at or near point 2
-2
INFO: Self-intersection at or near point 2 -2
FAILED
1. cu_raster_geometry.c:296 -
CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 0,1 -1,0 -1,0 -5,4 -5,5 -5,5
0,1 0)))")
2. cu_raster_geometry.c:308 -
0,1 0),(1 -1,1 -2,2 -2,2 -1,1 -1)))")
3. cu_raster_geometry.c:321 -
CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0
-1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))")
4. cu_raster_geometry.c:335 -
-1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3
-4,4 -4,4 -3,3 -3)))")
5. cu_raster_geometry.c:363 -
CU_ASSERT_STRING_EQUAL(wkt,"MULTIPOLYGON(((1 -4,2 -4,2 -3,3 -3,3 -4,4 -4,4
-5,3 -5,1 -5,1 -4)),((1 -4,0 -4,0 -1,1 -1,1 -2,2 -2,2 -3,1 -3,1 -4)),((3
-2,4 -2,4 -1,5 -1,5 -4,4 -4,4 -3,3 -3,3 -2)),((3 -2,2 -2,2 -1,1 -1,1 0,4
0,4 -1,3 -1,3 -2)))")
Test: test_raster_perimeter ...passed
Test: test_raster_pixel_as_polygon ...passed
Suite: raster_misc
Test: test_raster_cell_to_geopoint ...passed
Test: test_raster_geopoint_to_cell ...passed
Test: test_raster_from_two_rasters ...passed
Test: test_raster_compute_skewed_raster ...passed
Suite: band_stats
Test: test_band_stats ...passed
Test: test_band_value_count ...passed
Suite: band_misc
Test: test_band_get_nearest_pixel ...passed
Test: test_band_get_pixel_of_value ...passed
Test: test_pixel_set_to_array ...passed
Suite: mapalgebra
Test: test_raster_iterator ...passed
Test: test_band_reclass ...passed
Test: test_raster_colormap ...passed
Suite: spatial_relationship
Test: test_raster_geos_overlaps ...passed
Test: test_raster_geos_touches ...passed
Test: test_raster_geos_contains ...passed
Test: test_raster_geos_contains_properly ...passed
Test: test_raster_geos_covers ...passed
Test: test_raster_geos_covered_by ...passed
Test: test_raster_within_distance ...passed
Test: test_raster_fully_within_distance ...passed
Test: test_raster_intersects ...passed
Test: test_raster_same_alignment ...passed
Suite: misc
Test: test_rgb_to_hsv ...passed
Test: test_hsv_to_rgb ...passed
Test: test_util_gdal_open ...passed
Run Summary: Type Total Ran Passed Failed Inactive
suites 12 12 n/a 0 0
tests 65 65 63 2 0
asserts 45897 45897 45884 13 n/a
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4673#comment:5>
