[postgis-tickets] [PostGIS] #4720: Memory leak when using Geography
trac at osgeo.org
Sat Jul 11 17:11:16 PDT 2020
Reporter: kthujvu | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.0.x
Resolution: | Keywords: geography memory
Comment (by pramsey):
I'm afraid I'm not seeing this effect... at least not at anything remotely
the level you describe. My memory use under both PostGIS 3.0 and 3.1
(master) is climbing only veeeery slowly (14M usage after 4 mintes). It
*might* be a leak, but it's not the gusher you're seeing. Only difference
in my test is using the 50m dataset instead of 110m. I will attempt with
your exact data later.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4720#comment:1>
