[postgis-tickets] [PostGIS] #4720: Memory leak when using Geography
trac at osgeo.org
Sat Jul 18 04:38:06 PDT 2020
Reporter: kthujvu | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.0.x
Resolution: | Keywords: geography memory
Comment (by kthujvu):
I also cannot reproduce it with the 50m dataset.
Here is the full "test suite" I used, uses docker (sorry):
docker run --name "postgis" -p 25432:5432 -d -t kartoza/postgis:12.1
docker exec -it postgis bash
# then in the container itself:
apt update
apt install postgis # for shp2pgsql, update is needed first for the
package to be discoverable
apt install unzip
wget
https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/110m/cultural/ne_110m_admin_0_countries.zip
wget
https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/50m/cultural/ne_50m_admin_0_countries.zip
unzip ne_50m_admin_0_countries.zip
shp2pgsql -c -D -i -I -G ne_50m_admin_0_countries.shp | PGPASSWORD=docker
psql -h localhost -U docker gis
unzip ne_110m_admin_0_countries.zip
shp2pgsql -c -D -i -I -G ne_110m_admin_0_countries.shp | PGPASSWORD=docker
Then in
PGPASSWORD=docker psql -h localhost -U docker gis
I tested the following query:
WITH latitudes AS (
SELECT generate_series AS latitude
FROM generate_series(-90, 90, 0.1)
), longitudes AS (
SELECT generate_series AS longitude
FROM generate_series(-180, 180, 0.1)
), points AS (
SELECT ST_SetSRID(ST_Point(longitude, latitude), 4326)::geography
AS geog
FROM latitudes
CROSS JOIN longitudes
SELECT
geog,
SELECT name
FROM ne_50m_admin_0_countries AS ne
ORDER BY p.geog <-> ne.geog
LIMIT 1
FROM points AS p
That query on the ne_50m_admin_0_countries table: 250MB RAM (RES) usage
after 30 minutes
Same query with ne_110m_admin_0_countries: > 2G RAM (RES) and growing
~8MB/s after 15 minutes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4720#comment:2>
