[postgis-tickets] [PostGIS] #4660: Sensible number output semantics (was: Raise the max number of digits for double printing to 17)
trac at osgeo.org
Mon Jul 20 09:14:25 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Changes (by Algunenano):
* status: assigned => new
Old description:
> In #4543 I enforced a limit on the number of digits output by
> lwprint_double. This limit was already in place but not always effective,
> which could lead to issues in other functions not calculating the
> necessary buffer correctly, so they would overestimate to be safe.
> I set it to 15 digits, but it has come to my attention that some double
> numbers need up to 17 digits to be able to do the correct round trip, so
> I'm thinking on raising it from 15 to 17.
> It should be available for both ST_AsText and ST_AsGeoJSON, but the user
> setting (or default) is still in place (so if they request 8 digits they
> should get 8 and no more).
New description:
~~In #4543 I enforced a limit on the number of digits output by
necessary buffer correctly, so they would overestimate to be safe.~~
~~I set it to 15 digits, but it has come to my attention that some double
I'm thinking on raising it from 15 to 17.~~
~~It should be available for both ST_AsText and ST_AsGeoJSON, but the user
should get 8 and no more).~~
Comes from 2 different mail threads:
* https://lists.osgeo.org/pipermail/postgis-devel/2020-April/028510.html
* https://lists.osgeo.org/pipermail/postgis-devel/2020-April/028528.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4660#comment:1>
