[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-9-g672e6d0
git at osgeo.org
git at osgeo.org
Wed Jul 29 01:53:57 PDT 2020
the project "PostGIS".
via 672e6d06db6132bc7ad83685d4903b0b43eac8f9 (commit)
from 13437122770db9f07be062feddba80210bee0a0d (commit)
revisions in full, below.
commit 672e6d06db6132bc7ad83685d4903b0b43eac8f9
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Jul 28 16:17:07 2020 +0200
WKT/KML: Print doubles directly into stringbuffers
Closes https://github.com/postgis/postgis/pull/573
Closes #4729
diff --git a/NEWS b/NEWS
index 692b678..5448752 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,7 @@ Only tickets not included in 3.1.0alpha2
- The precision parameter now also affects the scientific notation (before it was fixed [5-8]).
- All output functions now respect the requested precision (without any limits).
- The default precision is the same (9 for GeoJSON, 15 for everything else).
+ - #4729, WKT/KML: Print doubles directly into stringbuffers (Raúl Marín)
* Bug fixes *
diff --git a/liblwgeom/lwout_kml.c b/liblwgeom/lwout_kml.c
index 1e95487..45ff523 100644
--- a/liblwgeom/lwout_kml.c
+++ b/liblwgeom/lwout_kml.c
@@ -110,9 +110,7 @@ ptarray_to_kml2_sb(const POINTARRAY *pa, int precision, stringbuffer_t *sb)
for (j = 0; j < dims; j++)
if ( j ) stringbuffer_append_len(sb,",",1);
- char coord[OUT_DOUBLE_BUFFER_SIZE];
- int len = lwprint_double(d[j], precision, coord);
- stringbuffer_append_len(sb, coord, len);
+ stringbuffer_append_double(sb, d[j], precision);
return LW_SUCCESS;
diff --git a/liblwgeom/lwout_wkt.c b/liblwgeom/lwout_wkt.c
index ac3430f..d8f9743 100644
--- a/liblwgeom/lwout_wkt.c
+++ b/liblwgeom/lwout_wkt.c
@@ -76,6 +76,19 @@ static void empty_to_wkt_sb(stringbuffer_t *sb)
stringbuffer_append_len(sb, "EMPTY", 5);
+inline static void
+coordinate_to_wkt_sb(double *coords, stringbuffer_t *sb, uint32_t dimensions, int precision)
+ uint32_t d = 0;
+ stringbuffer_append_double(sb, coords[d], precision);
+ for (d = 1; d < dimensions; d++)
+ stringbuffer_append_len(sb, " ", 1);
* Point array is a list of coordinates. Depending on output mode,
* we may suppress some dimensions. ISO and Extended formats include
@@ -85,33 +98,29 @@ static void ptarray_to_wkt_sb(const POINTARRAY *ptarray, stringbuffer_t *sb, int
/* OGC only includes X/Y */
uint32_t dimensions = 2;
- uint32_t i, j;
/* ISO and extended formats include all dimensions */
if ( variant & ( WKT_ISO | WKT_EXTENDED ) )
dimensions = FLAGS_NDIMS(ptarray->flags);
+ stringbuffer_makeroom(sb, 2 + ((OUT_MAX_BYTES_DOUBLE + 1) * dimensions * ptarray->npoints));
/* Opening paren? */
if ( ! (variant & WKT_NO_PARENS) )
stringbuffer_append_len(sb, "(", 1);
/* Digits and commas */
- for (i = 0; i < ptarray->npoints; i++)
+ if (ptarray->npoints)
- double *dbl_ptr = (double*)getPoint_internal(ptarray, i);
+ uint32_t i = 0;
- /* Commas before ever coord but the first */
- if ( i > 0 )
- stringbuffer_append_len(sb, ",", 1);
+ double *dbl_ptr = (double *)getPoint_internal(ptarray, i);
+ coordinate_to_wkt_sb(dbl_ptr, sb, dimensions, precision);
- for (j = 0; j < dimensions; j++)
+ for (i = 1; i < ptarray->npoints; i++)
- /* Spaces before every ordinate but the first */
- if ( j > 0 )
- stringbuffer_append_len(sb, " ", 1);
- int len = lwprint_double(dbl_ptr[j], precision, coord);
+ stringbuffer_append_len(sb, ",", 1);
+ dbl_ptr = (double *)getPoint_internal(ptarray, i);
diff --git a/liblwgeom/stringbuffer.h b/liblwgeom/stringbuffer.h
index eac9ceb..a0324f6 100644
--- a/liblwgeom/stringbuffer.h
+++ b/liblwgeom/stringbuffer.h
@@ -105,4 +105,11 @@ stringbuffer_append(stringbuffer_t *s, const char *a)
int alen = strlen(a); /* Length of string to append */
stringbuffer_append_len(s, a, alen);
+inline static void
+stringbuffer_append_double(stringbuffer_t *s, double d, int precision)
+ stringbuffer_makeroom(s, OUT_MAX_BYTES_DOUBLE);
+ s->str_end += lwprint_double(d, precision, s->str_end);
#endif /* _STRINGBUFFER_H */
Summary of changes:
NEWS | 1 +
liblwgeom/lwout_kml.c | 4 +---
liblwgeom/lwout_wkt.c | 35 ++++++++++++++++++++++-------------
liblwgeom/stringbuffer.h | 7 +++++++
4 files changed, 31 insertions(+), 16 deletions(-)
hooks/post-receive
