[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-10-g510b23d
Wed Jul 29 03:22:54 PDT 2020
the project "PostGIS".
       via  510b23dc037e1ea3d225e4632461f374b71e8849 (commit)
      from  672e6d06db6132bc7ad83685d4903b0b43eac8f9 (commit)
revisions in full, below.
commit 510b23dc037e1ea3d225e4632461f374b71e8849
Author: Raúl Marín <git at rmr.ninja>
Date:   Tue Jul 28 17:45:01 2020 +0200
    Use lwprint_double for printing box types
    Includes BOX2D, BOX3D, BOX2DF and GIDX
    Closes #4533 (Only for 3.1+)
    Closes https://github.com/postgis/postgis/pull/574
diff --git a/NEWS b/NEWS
index 5448752..357c5a5 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ Only tickets not included in 3.1.0alpha2
         - All output functions now respect the requested precision (without any limits).
         - The default precision is the same (9 for GeoJSON, 15 for everything else).
   - #4729, WKT/KML: Print doubles directly into stringbuffers (Raúl Marín)
+  - #4533, Use the standard coordinate printing system for box types (Raúl Marín)
 * Bug fixes *
diff --git a/libpgcommon/gserialized_gist.c b/libpgcommon/gserialized_gist.c
index a1329ae..4aad26e 100644
--- a/libpgcommon/gserialized_gist.c
+++ b/libpgcommon/gserialized_gist.c
@@ -19,6 +19,7 @@
 /*#define POSTGIS_DEBUG_LEVEL 4*/
 #include "liblwgeom.h"         /* For standard geometry types. */
+#include "liblwgeom_internal.h"
 #include "lwgeom_pg.h"       /* For debugging macros. */
 #include "gserialized_gist.h"
@@ -30,30 +31,32 @@
 /* Generate human readable form for GIDX. */
 char* gidx_to_string(GIDX *a)
-	char *str, *rv;
-	int i, ndims;
+	static const int precision = 12;
+	char tmp[8 + 8 * (OUT_MAX_BYTES_DOUBLE + 1)] = {'G', 'I', 'D', 'X', '(', 0};
+	int len = 5;
+	int ndims;
-	if ( a == NULL )
+	if (a == NULL)
 		return pstrdup("<NULLPTR>");
-	/* 4 (GIDX_MAX_DIM) *
-	 * 2 (MAX & MIN) *
-	 * 20 (Max representation (e.g. -3.40282346639e+38) [19] + space)
-	 * = 4*2*20 = 160
-	 * + 9 [ 'GIDX(' = 5, ','  = 1, ' )' = 2 + '\0' = 1]
-	str = (char *)palloc(169);
-	rv = str;
 	ndims = GIDX_NDIMS(a);
-	str += sprintf(str, "GIDX(");
-	for ( i = 0; i < ndims; i++ )
-		str += sprintf(str, " %.12g", GIDX_GET_MIN(a,i));
-	str += sprintf(str, ",");
-		str += sprintf(str, " %.12g", GIDX_GET_MAX(a,i));
-	str += sprintf(str, " )");
+	for (int i = 0; i < ndims; i++)
+		tmp[len++] = ' ';
+		len += lwprint_double(GIDX_GET_MIN(a, i), precision, &tmp[len]);
+	tmp[len++] = ',';
+		tmp[len++] = ' ';
+		len += lwprint_double(GIDX_GET_MAX(a, i), precision, &tmp[len]);
+	tmp[len++] = ')';
-	return rv;
+	return pstrdup(tmp);
 /* Allocates a new GIDX on the heap of the requested dimensionality */
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index b6ce9a5..e5b2c27 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -46,6 +46,7 @@
 #include "../postgis_config.h"
 #include "gserialized_gist.h"	     /* For utility functions. */
@@ -116,14 +117,24 @@ typedef bool (*box2df_predicate)(const BOX2DF *a, const BOX2DF *b);
 static char* box2df_to_string(const BOX2DF *a)
-	char *rv = NULL;
+	char tmp[13 + 4 * OUT_MAX_BYTES_DOUBLE] = {'B', 'O', 'X', '2', 'D', 'F', '(', 0};
+	int len = 7;
-	if ( a == NULL )
+	if (a == NULL)
-	rv = palloc(128);
-	sprintf(rv, "BOX2DF(%.12g %.12g, %.12g %.12g)", a->xmin, a->ymin, a->xmax, a->ymax);
-	return rv;
+	len += lwprint_double(a->xmin, precision, &tmp[len]);
+	tmp[len++] = ' ';
+	len += lwprint_double(a->ymin, precision, &tmp[len]);
+	tmp[len++] = ',';
+	tmp[len++] = ' ';
+	len += lwprint_double(a->xmax, precision, &tmp[len]);
+	tmp[len++] = ' ';
+	len += lwprint_double(a->ymax, precision, &tmp[len]);
+	tmp[len++] = ')';
 /* Allocate a new copy of BOX2DF */
diff --git a/postgis/lwgeom_box.c b/postgis/lwgeom_box.c
index 4368728..b9cab7d 100644
--- a/postgis/lwgeom_box.c
+++ b/postgis/lwgeom_box.c
@@ -34,6 +34,7 @@
 #include <math.h>
 #include <float.h>
@@ -93,24 +94,30 @@ Datum BOX2D_in(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(BOX2D_out);
 Datum BOX2D_out(PG_FUNCTION_ARGS)
-	char tmp[500]; /* big enough */
+	char tmp[500] = {'B', 'O', 'X', '(', 0}; /* big enough */
+	static const int precision = 15;
 	char *result;
-	int size;
+	int size = 0;
 	GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
 	/* Avoid unaligned access to the gbox struct */
 	GBOX box_aligned;
 	memcpy(&box_aligned, box, sizeof(GBOX));
-	size = sprintf(tmp,
-		       "BOX(%.15g %.15g,%.15g %.15g)",
-		       box_aligned.xmin,
-		       box_aligned.ymin,
-		       box_aligned.xmax,
-		       box_aligned.ymax);
+	size = 4;
+	size += lwprint_double(box_aligned.xmin, precision, &tmp[size]);
+	tmp[size++] = ' ';
+	size += lwprint_double(box_aligned.ymin, precision, &tmp[size]);
+	tmp[size++] = ',';
+	size += lwprint_double(box_aligned.xmax, precision, &tmp[size]);
+	size += lwprint_double(box_aligned.ymax, precision, &tmp[size]);
-	result= palloc(size+1); /* +1= null term */
-	memcpy(result,tmp,size+1);
+	tmp[size++] = ')';
+	size += 1;
+	result = palloc(size + 1); /* +1= null term */
+	memcpy(result, tmp, size + 1);
 	result[size] = '\0';
 	PG_RETURN_CSTRING(result);
diff --git a/postgis/lwgeom_box3d.c b/postgis/lwgeom_box3d.c
index 9a34500..28448f1 100644
--- a/postgis/lwgeom_box3d.c
+++ b/postgis/lwgeom_box3d.c
@@ -33,6 +33,7 @@
 #include "lwgeom_box3d.h"
 #include <math.h>
@@ -40,8 +41,6 @@
 #include <string.h>
 #include <stdio.h>
-#define SHOW_DIGS_DOUBLE 15
-#define MAX_DIGS_DOUBLE (SHOW_DIGS_DOUBLE + 6 + 1 + 3 + 1)
  *  BOX3D_in - takes a string rep of BOX3D and returns internal rep
@@ -121,7 +120,9 @@ PG_FUNCTION_INFO_V1(BOX3D_out);
 Datum BOX3D_out(PG_FUNCTION_ARGS)
 	BOX3D *bbox = (BOX3D *)PG_GETARG_POINTER(0);
-	int size;
+	static int size = OUT_MAX_BYTES_DOUBLE * 6 + 5 + 2 + 4 + 5 + 1; /* double * 6 + "BOX3D"+ "()" + commas + null */
+	int i = 0;
 	char *result;
 	if (bbox == NULL)
@@ -131,19 +132,26 @@ Datum BOX3D_out(PG_FUNCTION_ARGS)
-	/* double digits + "BOX3D"+ "()" + commas + null */
-	size = MAX_DIGS_DOUBLE * 6 + 5 + 2 + 4 + 5 + 1;
 	result = (char *)palloc(size);
-	sprintf(result,
-		"BOX3D(%.15g %.15g %.15g,%.15g %.15g %.15g)",
-		bbox->xmin,
-		bbox->ymin,
-		bbox->zmin,
-		bbox->xmax,
-		bbox->ymax,
-		bbox->zmax);
+	result[i++] = 'B';
+	result[i++] = 'O';
+	result[i++] = 'X';
+	result[i++] = '3';
+	result[i++] = 'D';
+	result[i++] = '(';
+	i += lwprint_double(bbox->xmin, precision, &result[i]);
+	result[i++] = ' ';
+	i += lwprint_double(bbox->ymin, precision, &result[i]);
+	i += lwprint_double(bbox->zmin, precision, &result[i]);
+	result[i++] = ',';
+	i += lwprint_double(bbox->xmax, precision, &result[i]);
+	i += lwprint_double(bbox->ymax, precision, &result[i]);
+	i += lwprint_double(bbox->zmax, precision, &result[i]);
+	result[i++] = ')';
+	result[i++] = '\0';
diff --git a/regress/core/in_geohash_expected b/regress/core/in_geohash_expected
index d10a378..35937cf 100644
--- a/regress/core/in_geohash_expected
+++ b/regress/core/in_geohash_expected
@@ -1,7 +1,7 @@
-box2dfromgeohash_01|BOX(-115.172816 36.114646,-115.172816 36.114646)
+box2dfromgeohash_01|BOX(-115.17281600000001 36.11464599999999,-115.172816 36.114646)
 box2dfromgeohash_02|BOX(-180 -90,180 90)
-box2dfromgeohash_03|BOX(-115.172816 36.114646,-115.172816 36.114646)
-box2dfromgeohash_04|BOX(-115.172816 36.114646,-115.172816 36.114646)
+box2dfromgeohash_03|BOX(-115.17281600000001 36.11464599999999,-115.172816 36.114646)
+box2dfromgeohash_04|BOX(-115.17281600000001 36.11464599999999,-115.172816 36.114646)
 geomfromgeohash_01|POLYGON((-115.17281600000001 36.11464599999999,-115.17281600000001 36.114646,-115.172816 36.114646,-115.172816 36.11464599999999,-115.17281600000001 36.11464599999999))
 geomfromgeohash_02|POLYGON((-180 -90,-180 90,180 90,180 -90,-180 -90))
 geomfromgeohash_03|POLYGON((-115.17281600000001 36.11464599999999,-115.17281600000001 36.114646,-115.172816 36.114646,-115.172816 36.11464599999999,-115.17281600000001 36.11464599999999))
Summary of changes:
 NEWS                             |  1 +
 libpgcommon/gserialized_gist.c   | 41 +++++++++++++++++++++-------------------
 postgis/gserialized_gist_2d.c    | 21 +++++++++++++++-----
 postgis/lwgeom_box.c             | 27 ++++++++++++++++----------
 postgis/lwgeom_box3d.c           | 38 ++++++++++++++++++++++---------------
 regress/core/in_geohash_expected |  6 +++---
 6 files changed, 82 insertions(+), 52 deletions(-)
hooks/post-receive
