[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Sun Jun 21 04:00:41 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by zezzagio):
Replying to [comment:19 strk]:
> Git work is great, but someone will need to double check
Of course someone will need to double check! it's the because I don't
understand.
> Git work is great, but someone will need to double check this because
> the header file also says that function wants the PG name, not the DBF
> name:
> const char *colmap_dbf_by_pg(colmap *map, const char *pgname);
> const char *colmap_pg_by_dbf(colmap *map, const char *dbfname);
Exactly so! the header says it wants the PG name, the code called it with
the DBF name.
> Those signatures are in loader/shpcommon.h, lacking a comment.
> The help output from shp2pgsql says the format is:
> COLUMNNAME DBFFIELD1
> AVERYLONGCOLUMNNAME DBFFIELD2
> So we have the PostgreSQL column name on the left and the
> DBF field name on the right.
> The _same_ format is expected by pgsql2shp
> (yes, key on the right in this case).
No, the "key" (i.e. the searched value) is on the left for pgsql2shp. We
are searching for a PG column, in order to get the corresponding DBF
column.
The functions colmap_dbf_by_pg and colmap_pg_by_dbf are quite similar (and
quite simple): they compare an array of strings (map) against a value
(key).
In the case of colmap_dbf_by_pg, the array of PG fields names is compared
against the PG field name (returning the corresponding DBF field name); in
the case of colmap_pg_by_dbf the array of DBF fields names is compared
against the DBF field name (returning the correponding PG field name.)
The mapping file is the same; this seems a good choice to me.
> You are changing this:
> - const char *mapped = colmap_dbf_by_pg(&state->column_map,
dbffieldname);
> + const char *mapped = colmap_dbf_by_pg(&state->column_map,
pgfieldname);
> Does not seem to match with parameter names in signature...
I don't understand. It ''didn't'' match, in fact; now it does.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:21>
