[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Mon Jun 22 09:54:22 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
> - const char *mapped = colmap_dbf_by_pg(&state->column_map,
dbffieldname);
> + const char *mapped = colmap_dbf_by_pg(&state->column_map,
pgfieldname);
> Does not seem to match with parameter names in signature...
I don't understand. It 'didn't' match, in fact; now it does.
Ah, sorry, yes, now I see. I'll run tests locally and then push the
fix. Thanks a lot !
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:22>
