[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-26-g7f44267
Mon Mar 2 15:05:43 PST 2020
the project "PostGIS".
       via  7f4426716f561187175d73bfff330343b25a7be9 (commit)
      from  57ff7ac784f60dc2a455e5f330963ba11750f6f7 (commit)
revisions in full, below.
commit 7f4426716f561187175d73bfff330343b25a7be9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Mar 2 15:05:37 2020 -0800
    repair typo in linestring literal, references #4641
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 21363eb..15313b4 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1691,7 +1691,7 @@ CREATE OR REPLACE FUNCTION ST_MakeEnvelope(float8, float8, float8, float8, integ
 -- Availability: 3.0.0
 -- Changed: 3.1.0 - add margin=0.0 parameter
-CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING((-20037508.342789244 -20037508.342789244, 20037508.342789244 20037508.342789244)'::geometry, margin float8 DEFAULT 0.0)
+CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789244 -20037508.342789244, 20037508.342789244 20037508.342789244)'::geometry, margin float8 DEFAULT 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_TileEnvelope'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
Summary of changes:
 postgis/postgis.sql.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
