[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-27-gc6d89b4
git at osgeo.org
git at osgeo.org
Mon Mar 2 15:16:35 PST 2020
the project "PostGIS".
via c6d89b476d95bc6c6fb3e9ced843fff553319144 (commit)
from 7f4426716f561187175d73bfff330343b25a7be9 (commit)
revisions in full, below.
commit c6d89b476d95bc6c6fb3e9ced843fff553319144
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 2 15:16:29 2020 -0800
harmonize outputs with new precise base srs, reference #4641
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index 5503d05..b8e8249 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -265,26 +265,26 @@ select '225', ST_Expand('BOX(-2 3, -1 6'::BOX2D, 4, 2);
select '226', ST_SRID(ST_Expand('SRID=4326;POINT (0 0)'::geometry, 1))=4326;
-- ST_TileEnvelope()
-select '227', ST_AsEWKT(ST_TileEnvelope(-1, 0, 0));
-select '228', ST_AsEWKT(ST_TileEnvelope(0, 0, 1));
-select '229', ST_AsEWKT(ST_TileEnvelope(0, 0, 0));
-select '230', ST_AsText(ST_TileEnvelope(4, 8, 8), 7);
-select '231', ST_AsEWKT(ST_TileEnvelope(4, 15, 15));
-select '232', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
-select '233', ST_AsEWKT(ST_TileEnvelope(4, 15, 15, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
-select '234', ST_AsEWKT(ST_TileEnvelope(4, 0, 0, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
-select '235', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-200, -100, 200, 100, 0)));
-select '236', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => 0.1));
-select '237', ST_AsEWKT(ST_TileEnvelope(1, 0, 0, margin => 0.1));
-select '238', ST_AsEWKT(ST_TileEnvelope(2, 1, 3, margin => 0.5));
-select '239', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.5));
-select '240', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.51));
-select '241', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.4));
-select '250', ST_AsEWKT(ST_TileEnvelope(10,300,387));
-select '251', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.1));
-select '252', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.5));
-select '253', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 2));
-select '254', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => -0.3));
+select '227', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(-1, 0, 0) ,0.01));
+select '228', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 1), 0.01));
+select '229', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 0), 0.01));
+select '230', ST_AsText(ST_SnapToGrid(ST_TileEnvelope(4, 8, 8), 0.01));
+select '231', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(4, 15, 15),0.01));
+select '232', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-100, -100, 100, 100, 0)), 0.01));
+select '233', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(4, 15, 15, ST_MakeEnvelope(-100, -100, 100, 100, 0)), 0.01));
+select '234', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(4, 0, 0, ST_MakeEnvelope(-100, -100, 100, 100, 0)), 0.01));
+select '235', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-200, -100, 200, 100, 0)), 0.01));
+select '236', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 0, margin => 0.1), 0.01));
+select '237', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(1, 0, 0, margin => 0.1), 0.01));
+select '238', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(2, 1, 3, margin => 0.5), 0.01));
+select '239', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 0, margin => -0.5), 0.01));
+select '240', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 0, margin => -0.51), 0.01));
+select '241', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(0, 0, 0, margin => -0.4), 0.01));
+select '250', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(10,300,387), 0.01));
+select '251', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(10,300,387, margin => 0.1), 0.01));
+select '252', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(10,300,387, margin => 0.5), 0.01));
+select '253', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(10,300,387, margin => 2), 0.01));
+select '254', ST_AsEWKT(ST_SnapToGrid(ST_TileEnvelope(10,300,387, margin => -0.3), 0.01));
-- ST_Hexagon()
select '300', ST_AsEWKT(ST_SnapToGrid(ST_Hexagon(10, 0, 0),0.00001));
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index aed3e61..7e1c312 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -196,24 +196,24 @@ ERROR: geometry contains non-closed rings
226|t
ERROR: ST_TileEnvelope: Invalid tile zoom value, -1
ERROR: ST_TileEnvelope: Invalid tile y value, 1
-229|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
-230|POLYGON((0 -2504688.5428486,0 0,2504688.5428486 0,2504688.5428486 -2504688.5428486,0 -2504688.5428486))
-231|SRID=3857;POLYGON((17532819.7999404 -20037508.342789,17532819.7999404 -17532819.7999404,20037508.342789 -17532819.7999404,20037508.342789 -20037508.342789,17532819.7999404 -20037508.342789))
+229|SRID=3857;POLYGON((-20037508.34 -20037508.34,-20037508.34 20037508.34,20037508.34 20037508.34,20037508.34 -20037508.34,-20037508.34 -20037508.34))
+230|POLYGON((0 -2504688.54,0 0,2504688.54 0,2504688.54 -2504688.54,0 -2504688.54))
+231|SRID=3857;POLYGON((17532819.8 -20037508.34,17532819.8 -17532819.8,20037508.34 -17532819.8,20037508.34 -20037508.34,17532819.8 -20037508.34))
232|POLYGON((0 -12.5,0 0,12.5 0,12.5 -12.5,0 -12.5))
233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
235|POLYGON((0 -12.5,0 0,25 0,25 -12.5,0 -12.5))
-236|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
-237|SRID=3857;POLYGON((-22041259.1770679 -2003750.8342789,-22041259.1770679 20037508.342789,2003750.8342789 20037508.342789,2003750.8342789 -2003750.8342789,-22041259.1770679 -2003750.8342789))
-238|SRID=3857;POLYGON((-15028131.2570918 -20037508.342789,-15028131.2570918 -5009377.08569725,5009377.08569725 -5009377.08569725,5009377.08569725 -20037508.342789,-15028131.2570918 -20037508.342789))
-239|SRID=3857;POLYGON((0 0,0 0,0 0,0 0,0 0))
+236|SRID=3857;POLYGON((-20037508.34 -20037508.34,-20037508.34 20037508.34,20037508.34 20037508.34,20037508.34 -20037508.34,-20037508.34 -20037508.34))
+237|SRID=3857;POLYGON((-22041259.18 -2003750.83,-22041259.18 20037508.34,2003750.83 20037508.34,2003750.83 -2003750.83,-22041259.18 -2003750.83))
+238|SRID=3857;POLYGON((-15028131.26 -20037508.34,-15028131.26 -5009377.09,5009377.09 -5009377.09,5009377.09 -20037508.34,-15028131.26 -20037508.34))
+239|SRID=3857;POLYGON EMPTY
ERROR: ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
-241|SRID=3857;POLYGON((-4007501.6685578 -4007501.6685578,-4007501.6685578 4007501.6685578,4007501.6685578 4007501.6685578,4007501.6685578 -4007501.6685578,-4007501.6685578 -4007501.6685578))
-250|SRID=3857;POLYGON((-8296780.79818607 4852834.05176921,-8296780.79818607 4891969.81025122,-8257645.03970406 4891969.81025122,-8257645.03970406 4852834.05176921,-8296780.79818607 4852834.05176921))
-251|SRID=3857;POLYGON((-8300694.37403427 4848920.47592101,-8300694.37403427 4895883.38609942,-8253731.46385586 4895883.38609942,-8253731.46385586 4848920.47592101,-8300694.37403427 4848920.47592101))
-252|SRID=3857;POLYGON((-8316348.67742708 4833266.17252821,-8316348.67742708 4911537.68949223,-8238077.16046306 4911537.68949223,-8238077.16046306 4833266.17252821,-8316348.67742708 4833266.17252821))
-253|SRID=3857;POLYGON((-8375052.31515009 4774562.53480519,-8375052.31515009 4970241.32721524,-8179373.52274004 4970241.32721524,-8179373.52274004 4774562.53480519,-8375052.31515009 4774562.53480519))
-254|SRID=3857;POLYGON((-8285040.07064147 4864574.77931381,-8285040.07064147 4880229.08270662,-8269385.76724866 4880229.08270662,-8269385.76724866 4864574.77931381,-8285040.07064147 4864574.77931381))
+241|SRID=3857;POLYGON((-4007501.67 -4007501.67,-4007501.67 4007501.67,4007501.67 4007501.67,4007501.67 -4007501.67,-4007501.67 -4007501.67))
+250|SRID=3857;POLYGON((-8296780.8 4852834.05,-8296780.8 4891969.81,-8257645.04 4891969.81,-8257645.04 4852834.05,-8296780.8 4852834.05))
+251|SRID=3857;POLYGON((-8300694.37 4848920.48,-8300694.37 4895883.39,-8253731.46 4895883.39,-8253731.46 4848920.48,-8300694.37 4848920.48))
+252|SRID=3857;POLYGON((-8316348.68 4833266.17,-8316348.68 4911537.69,-8238077.16 4911537.69,-8238077.16 4833266.17,-8316348.68 4833266.17))
+253|SRID=3857;POLYGON((-8375052.32 4774562.53,-8375052.32 4970241.33,-8179373.52 4970241.33,-8179373.52 4774562.53,-8375052.32 4774562.53))
+254|SRID=3857;POLYGON((-8285040.07 4864574.78,-8285040.07 4880229.08,-8269385.77 4880229.08,-8269385.77 4864574.78,-8285040.07 4864574.78))
300|POLYGON((-10 0,-5 -8.66025,5 -8.66025,10 0,5 8.66025,-5 8.66025,-10 0))
301|POLYGON((5 25.98076,10 17.32051,20 17.32051,25 25.98076,20 34.64102,10 34.64102,5 25.98076))
302|POLYGON((-25 -8.66025,-20 -17.32051,-10 -17.32051,-5 -8.66025,-10 0,-20 0,-25 -8.66025))
Summary of changes:
regress/core/regress.sql | 40 ++++++++++++++++++++--------------------
regress/core/regress_expected | 26 +++++++++++++-------------
2 files changed, 33 insertions(+), 33 deletions(-)
hooks/post-receive
