[postgis-tickets] [SCM] PostGIS branch master updated.	3.1.0alpha1-35-g10f91f0
    git at osgeo.org
    git at osgeo.org
    Wed Mar  4 18:06:51 PST 2020
the project "PostGIS".
       via  10f91f070e04ffa7866560b682694b584de54b4e (commit)
       via  139613cdbaab7d72633925b2f8d848d58644829d (commit)
       via  a975224659e694cd22970b3fe3f8b1add919be58 (commit)
      from  2f7b95e6b7e783c1ed9260c217c0d237ea3bd9a6 (commit)
revisions in full, below.
commit 10f91f070e04ffa7866560b682694b584de54b4e
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Mar 4 21:06:41 2020 -0500
    Add example for ST_BandPath, and correct notice, just returns null,not error for in db
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index ac9a4ac..69e37a2 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -4011,15 +4011,15 @@ select st_bandisnodata(rast, 2) from dummy_rast where rid = 1; -- Expected false
 			<refsection>
 				<title>Description</title>
-				<para>Returns system file path to a band.  Throws an error if called with an in db band.</para>
+				<para>Returns system file path to a band.  Returns null for in db raster bands.</para>
 				</refsection>
 				<refsection>
 					<title>Examples</title>
-					<programlisting><!-- TODO: -->
-					</programlisting>
+					<programlisting>SELECT rid, ST_BandPath(rast,1) AS file_path
+FROM dem
+LIMIT 1;</programlisting>
 			</refsection>
 			<refsection>
commit 139613cdbaab7d72633925b2f8d848d58644829d
Merge: a975224 2f7b95e
Date:   Wed Mar 4 20:42:00 2020 -0500
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit a975224659e694cd22970b3fe3f8b1add919be58
Date:   Fri Feb 21 22:53:56 2020 -0500
    Explain more what ST_Transform axis aligned does
index 7cf5587..b04f6cf 100644
@@ -6942,9 +6942,13 @@ SELECT rid, (meta).* FROM bar
 					ST_Transform is often confused with ST_SetSRID(). ST_Transform actually changes the coordinates of a raster (and resamples the pixel values) from one spatial reference system to another, while ST_SetSRID() simply changes the SRID identifier of the raster.
 				</para>
-				<para>
-					Unlike the other variants, Variant 3 requires a reference raster as <varname>alignto</varname>. The transformed raster will be transformed to the spatial reference system (SRID) of the reference raster and be aligned (ST_SameAlignment = TRUE) to the reference raster.
-				</para>
+				<note>
+					<para>
+						If you are transforming more than one tile, such as a table of coverage rasters you should use the <code>ST_Transform(rast,alignto)</code> (Variant 3)
+						to ensure the tiles will all have same alignment (needed by many operations such as ST_Union) and minimize on gaps between tiles.
+					</para>
+					<para>Unlike the other variants, Variant 3 requires a reference raster as <varname>alignto</varname>. The transformed raster will be transformed to the spatial reference system (SRID) of the reference raster and be aligned (ST_SameAlignment = TRUE) to the reference raster.</para>
+				</note>
 				<note>
 					<para>
@@ -6952,8 +6956,9 @@ SELECT rid, (meta).* FROM bar
 					</para>
 				</note>
-				<para>Availability: 2.0.0  Requires GDAL 1.6.1+</para>
 				<para>Enhanced: 2.1.0 Addition of ST_Transform(rast, alignto) variant</para>
+				<para>Availability: 2.0.0  Requires GDAL 1.6.1+</para>
 			</refsection>
 			<refsection>
Summary of changes:
 doc/reference_raster.xml | 21 +++++++++++++--------
 1 file changed, 13 insertions(+), 8 deletions(-)
hooks/post-receive
